path: root/posix-users/index.rst (follow)
* Add unicode support for commonly used characters like copyright.Chris Johns2019-02-281-3/+5
| | | | | - This change makes the copyright character easier to see on editors lacking good unicode rendering support, ie terminals.
* Use pathto() on the genindex URL to make it relative.Chris Johns2019-02-151-2/+0
* Reformat and update copyright and license noticesSebastian Huber2019-01-141-8/+7
| | | | | | | | For everything before 2015 an OAR copyright is assumed. Later copyright notices are based on Git commits on a best effort basis. The copyright notices of the "RTEMS Software Engineering Handbook" and the "RTEMS CPU Architecture Supplement" are incomplete.
* Simplify SPDX-License-Identifier commentSebastian Huber2019-01-111-1/+1
* Add common header.rst to reduce copy and pasteSebastian Huber2019-01-091-23/+1
* Update the copyright year.Chris Johns2018-10-191-1/+1
* build: Fix indexing so it works on HTML and PDF.Chris Johns2018-08-211-1/+1
| | | | | | | | | | | | - Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503
* Add indexes to all documents.Chris Johns2017-11-121-2/+1
| | | | Update #3229.
* Update copyright notices.Chris Johns2017-08-111-4/+7
* POSIX Users: Add posix_devctl()Joel Sherrill2017-04-251-0/+1
* Update document titles for consistencyJoel Sherrill2017-01-111-5/+5
* Rename all manuals with an _ to have a -. It helps released naming of files.Chris Johns2016-11-031-0/+67
