* | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 2018-08-21 | 1 | -4/+0 |
| | | | | | | | | | | | | - Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | ||||
* | Add indexes to all documents. | Chris Johns | 2017-11-12 | 1 | -0/+4 |
Update #3229. |
