2018-08-21 | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 2 | -5/+1 | |
- Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | |||||
2018-03-09 | Update the POSIX Compliance Tracking Spreadsheet. Add standards. | Joel Sherrill | 6 | -1208/+1434 | |
This update adds the following: C11 Programming Language Standard FACE Technical Standard Edition 3.0 (four profiles) Software Communication Architecture Specification 2.2.2 (one profile) Software Communication Architecture Specification 4.1 (three profiles) | |||||
2018-03-09 | posix-compliance: Add description of standards | Joel Sherrill | 3 | -5/+84 | |
2017-11-12 | Add indexes to all documents. | Chris Johns | 2 | -2/+5 | |
Update #3229. | |||||
2017-11-09 | Change RTEMS version to 5 | Sebastian Huber | 1 | -2/+2 | |
Update #3220. | |||||
2017-10-13 | posix-compliance: Latex does not like an empty glossary. | Chris Johns | 1 | -0/+5 | |
2017-10-13 | posix-compliance: Reference the generated content via the include file. | Chris Johns | 5 | -7/+24 | |
- Move the copyright to the top of the generated file. - Add a glossary and references section. | |||||
2017-10-12 | posix-compliance: Fix the pdflatex file created by Sphinx. | Chris Johns | 1 | -1/+1 | |
2017-10-12 | build: Remove the grouping in posix-compliance. | Chris Johns | 1 | -1/+0 | |
2017-10-12 | posix-compliance: Add automatic generation of the ReST file from CSV data. | Chris Johns | 3 | -1/+291 | |
Closes #3177. | |||||
2017-10-12 | New version of POSIX Compliance Guide | Joel Sherrill | 8 | -0/+1412 | |
This is a replacement of the POSIX 1003.1 Compliance Guide. It will be generated from a .csv file. Updates #3177. |
