README-cvs.txt will need to be updated each time the spreadsheet is updated.
The spreadsheet is managed and maintained externally and has a version in
the name. We do not want that in the repository because a diff of the CSV
should always be much smaller than a "delete old/add new" patch.
The new version of the API tracking spreadsheet includes FACE
Technical Standard, Edition 3.1 as well as a few additions to
what RTEMS supports. The generation script and discussion of
standards was updated to reflect the inclusion of a new Edition
of the FACE Technical Standard.
Closes #4380.
These methods have long been provided and this change is needed on the
5.x branch and master.
Closes #4075.
There are still sys.path hacks in the conf.py files. They cannot
be removed because the instance of python running the sphinx-build
command does not see our top level path hacks. I looked at using
PYTHONPATH but I could not figure out how to set a process environ
var for a waf build instance.
This avoids conflicts with standard packages such as PIL (Python Imaging
Library).
In the RTEMS POSIX 1003.1 Compliance Guide it says:
The following methods and variables in <sys/times.h> are supported:
- times()
- utimes()
But according to the official POSIX Specifications
http://pubs.opengroup.org/onlinepubs/9699919799/basedefs/sys_times.h.html,
<sys/times.h> only declares times(), and utimes() is decleared by
<sys/time.h> (notice that it's time, not times) according to
http://pubs.opengroup.org/onlinepubs/9699919799/functions/utimensat.html
and http://pubs.opengroup.org/onlinepubs/9699919799/basedefs/sys_time.h.html.
This patch fixes this error.
This work was part of GCI 2018.
This update adds the following:
C11 Programming Language Standard
FACE Technical Standard Edition 3.0 (four profiles)
Software Communication Architecture Specification 2.2.2 (one profile)
Software Communication Architecture Specification 4.1 (three profiles)
- Move the copyright to the top of the generated file.
- Add a glossary and references section.
Closes #3177.
This is a replacement of the POSIX 1003.1 Compliance Guide. It
will be generated from a .csv file.
Updates #3177.
To use:
1. Install aspell
2. waf spell <list of files>
* waf spell mydoc.rst
* waf spell *.rst
This uses a custom dictionary stored in common/spell/dict/. We should add all
RTEMS and programming terms to this to ensure we are consistent.
Amar.
Needed to switch due to increasing complexity.
