path: root/posix-compliance/wscript (follow)
* posix-compliance: Change utimes() from sys/times.h to sys/time.hMarçal Comajoan Cara2018-12-091-1/+1
| | | | | | | | | | | | | | | | | | | In the RTEMS POSIX 1003.1 Compliance Guide it says: The following methods and variables in <sys/times.h> are supported: - times() - utimes() But according to the official POSIX Specifications http://pubs.opengroup.org/onlinepubs/9699919799/basedefs/sys_times.h.html, <sys/times.h> only declares times(), and utimes() is decleared by <sys/time.h> (notice that it's time, not times) according to http://pubs.opengroup.org/onlinepubs/9699919799/functions/utimensat.html and http://pubs.opengroup.org/onlinepubs/9699919799/basedefs/sys_time.h.html. This patch fixes this error. This work was part of GCI 2018.
* Update the POSIX Compliance Tracking Spreadsheet. Add standards.Joel Sherrill2018-03-091-1/+1
| | | | | | | | | This update adds the following: C11 Programming Language Standard FACE Technical Standard Edition 3.0 (four profiles) Software Communication Architecture Specification 2.2.2 (one profile) Software Communication Architecture Specification 4.1 (three profiles)
* posix-compliance: Reference the generated content via the include file.Chris Johns2017-10-131-1/+2
| | | | | - Move the copyright to the top of the generated file. - Add a glossary and references section.
* build: Remove the grouping in posix-compliance.Chris Johns2017-10-121-1/+0
* posix-compliance: Add automatic generation of the ReST file from CSV data.Chris Johns2017-10-121-1/+23
| | | | Closes #3177.
* New version of POSIX Compliance GuideJoel Sherrill2017-10-121-0/+11
This is a replacement of the POSIX 1003.1 Compliance Guide. It will be generated from a .csv file. Updates #3177.
