There are still sys.path hacks in the conf.py files. They cannot
be removed because the instance of python running the sphinx-build
command does not see our top level path hacks. I looked at using
PYTHONPATH but I could not figure out how to set a process environ
var for a waf build instance.
This avoids conflicts with standard packages such as PIL (Python Imaging
Library).
In the RTEMS POSIX 1003.1 Compliance Guide it says:
The following methods and variables in <sys/times.h> are supported:
- times()
- utimes()
But according to the official POSIX Specifications
http://pubs.opengroup.org/onlinepubs/9699919799/basedefs/sys_times.h.html,
<sys/times.h> only declares times(), and utimes() is decleared by
<sys/time.h> (notice that it's time, not times) according to
http://pubs.opengroup.org/onlinepubs/9699919799/functions/utimensat.html
and http://pubs.opengroup.org/onlinepubs/9699919799/basedefs/sys_time.h.html.
This patch fixes this error.
This work was part of GCI 2018.
This update adds the following:
C11 Programming Language Standard
FACE Technical Standard Edition 3.0 (four profiles)
Software Communication Architecture Specification 2.2.2 (one profile)
Software Communication Architecture Specification 4.1 (three profiles)
- Move the copyright to the top of the generated file.
- Add a glossary and references section.
Closes #3177.
This is a replacement of the POSIX 1003.1 Compliance Guide. It
will be generated from a .csv file.
Updates #3177.
