- This change makes the copyright character easier to see on editors
lacking good unicode rendering support, ie terminals.
For everything before 2015 an OAR copyright is assumed. Later copyright
notices are based on Git commits on a best effort basis.
The copyright notices of the "RTEMS Software Engineering Handbook" and
the "RTEMS CPU Architecture Supplement" are incomplete.
- Remove all genindex.rst files, these are generated and should not
exist in our source.
- Fix the HTML templates so the local specialisation works.
- Add a index link to the sidebar for HTML.
Note, there is no TOC entry for the index in the PDF output and I
cannot figure out how to add one.
Closes #3503
Update #3229.
- Move the copyright to the top of the generated file.
- Add a glossary and references section.
This is a replacement of the POSIX 1003.1 Compliance Guide. It
will be generated from a .csv file.
Updates #3177.
