2019-02-08 | build: Prepend project common path | Sebastian Huber | 1 | -1/+1 | |
This avoids conflicts with standard packages such as PIL (Python Imaging Library). | |||||
2017-10-12 | posix-compliance: Fix the pdflatex file created by Sphinx. | Chris Johns | 1 | -1/+1 | |
2017-10-12 | New version of POSIX Compliance Guide | Joel Sherrill | 1 | -1/+3 | |
This is a replacement of the POSIX 1003.1 Compliance Guide. It will be generated from a .csv file. Updates #3177. | |||||
2017-03-20 | Use a single top level version number. | Chris Johns | 1 | -4/+5 | |
2017-01-11 | Update document titles for consistency | Joel Sherrill | 1 | -1/+1 | |
2016-11-03 | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 1 | -2/+1 | |
2016-05-02 | Add PDF generation support use with --pdf | Amar Takhar | 1 | -0/+4 | |
2016-05-02 | Rework how conf.py is handled. | Amar Takhar | 1 | -0/+8 | |
Needed to switch due to increasing complexity. |
