2017-03-27 | waf: Cleaner formatting to see the importing. | Chris Johns | 1 | -2/+7 | |
2017-03-20 | Use a single top level version number. | Chris Johns | 1 | -5/+5 | |
2017-01-11 | Update document titles for consistency | Joel Sherrill | 2 | -4/+4 | |
2016-10-28 | porting: Review and tidy up multiple formatting issues. | Joel Sherrill | 11 | -187/+223 | |
2016-10-29 | Remove the old files. | Chris Johns | 1 | -1920/+0 | |
2016-10-27 | porting: Fix code-block markup | Joel Sherrill | 7 | -71/+71 | |
2016-10-27 | rtems-docs: Fix many unnecessary back slashes | Joel Sherrill | 5 | -64/+64 | |
2016-05-20 | Set SPDX License Identifier in each source file. | Chris Johns | 14 | -0/+28 | |
2016-05-02 | Add PDF generation support use with --pdf | Amar Takhar | 2 | -6/+5 | |
2016-05-02 | Add support for spellchecking with a custom dictionary. | Amar Takhar | 1 | -1/+1 | |
To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar. | |||||
2016-05-02 | Convert all Unicode to ASCII(128) | Amar Takhar | 9 | -22/+22 | |
2016-05-02 | Rework how conf.py is handled. | Amar Takhar | 2 | -9/+9 | |
Needed to switch due to increasing complexity. | |||||
2016-05-02 | Rename old document for reference only. | Amar Takhar | 1 | -0/+0 | |
2016-05-02 | Split document into seperate files by section. | Amar Takhar | 13 | -1/+1858 | |
2016-05-02 | Fix markup | Amar Takhar | 1 | -0/+2 | |
