path: root/porting (follow)
* porting: Review and tidy up multiple formatting issues.Joel Sherrill2016-10-2811-187/+223
* Remove the old files.Chris Johns2016-10-291-1920/+0
* porting: Fix code-block markupJoel Sherrill2016-10-277-71/+71
* rtems-docs: Fix many unnecessary back slashesJoel Sherrill2016-10-275-64/+64
* Set SPDX License Identifier in each source file.Chris Johns2016-05-2014-0/+28
* Add PDF generation support use with --pdfAmar Takhar2016-05-022-6/+5
* Add support for spellchecking with a custom dictionary.Amar Takhar2016-05-021-1/+1
| | | | | | | | | | | | | | To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar.
* Convert all Unicode to ASCII(128)Amar Takhar2016-05-029-22/+22
* Rework how conf.py is handled.Amar Takhar2016-05-022-9/+9
| | | | Needed to switch due to increasing complexity.
* Rename old document for reference only.Amar Takhar2016-05-021-0/+0
* Split document into seperate files by section.Amar Takhar2016-05-0213-1/+1858
* Fix markupAmar Takhar2016-05-021-0/+2
* Initial reST documentation using Sphinx.Amar Takhar2016-05-023-0/+1936
