2019-01-14 | Reformat and update copyright and license notices | Sebastian Huber | 1 | -8/+5 | |
For everything before 2015 an OAR copyright is assumed. Later copyright notices are based on Git commits on a best effort basis. The copyright notices of the "RTEMS Software Engineering Handbook" and the "RTEMS CPU Architecture Supplement" are incomplete. | |||||
2019-01-11 | Simplify SPDX-License-Identifier comment | Sebastian Huber | 13 | -13/+13 | |
2019-01-11 | Remove superfluous "All rights reserved." | Sebastian Huber | 10 | -10/+0 | |
2019-01-11 | Use standard format for copyright lines | Sebastian Huber | 10 | -20/+10 | |
2019-01-09 | Add common header.rst to reduce copy and paste | Sebastian Huber | 1 | -23/+1 | |
2018-10-19 | Update the copyright year. | Chris Johns | 1 | -1/+1 | |
2018-08-21 | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 2 | -5/+1 | |
- Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | |||||
2017-11-12 | Add indexes to all documents. | Chris Johns | 2 | -2/+5 | |
Update #3229. | |||||
2017-08-11 | Update copyright notices. | Chris Johns | 1 | -29/+33 | |
2017-03-27 | waf: Cleaner formatting to see the importing. | Chris Johns | 1 | -2/+7 | |
2017-03-20 | Use a single top level version number. | Chris Johns | 1 | -5/+5 | |
2017-01-11 | Update document titles for consistency | Joel Sherrill | 2 | -4/+4 | |
2016-10-28 | porting: Review and tidy up multiple formatting issues. | Joel Sherrill | 11 | -187/+223 | |
2016-10-29 | Remove the old files. | Chris Johns | 1 | -1920/+0 | |
2016-10-27 | porting: Fix code-block markup | Joel Sherrill | 7 | -71/+71 | |
2016-10-27 | rtems-docs: Fix many unnecessary back slashes | Joel Sherrill | 5 | -64/+64 | |
2016-05-20 | Set SPDX License Identifier in each source file. | Chris Johns | 14 | -0/+28 | |
2016-05-02 | Add PDF generation support use with --pdf | Amar Takhar | 2 | -6/+5 | |
2016-05-02 | Add support for spellchecking with a custom dictionary. | Amar Takhar | 1 | -1/+1 | |
To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar. | |||||
2016-05-02 | Convert all Unicode to ASCII(128) | Amar Takhar | 9 | -22/+22 | |
2016-05-02 | Rework how conf.py is handled. | Amar Takhar | 2 | -9/+9 | |
Needed to switch due to increasing complexity. | |||||
2016-05-02 | Rename old document for reference only. | Amar Takhar | 1 | -0/+0 | |
2016-05-02 | Split document into seperate files by section. | Amar Takhar | 13 | -1/+1858 | |
2016-05-02 | Fix markup | Amar Takhar | 1 | -0/+2 | |
