* | Update copyright notices. | Chris Johns | 2017-08-11 | 1 | -29/+33 |
* | waf: Cleaner formatting to see the importing. | Chris Johns | 2017-03-27 | 1 | -2/+7 |
* | Use a single top level version number. | Chris Johns | 2017-03-20 | 1 | -5/+5 |
* | Update document titles for consistency | Joel Sherrill | 2017-01-11 | 2 | -4/+4 |
* | porting: Review and tidy up multiple formatting issues. | Joel Sherrill | 2016-10-28 | 11 | -187/+223 |
* | Remove the old files. | Chris Johns | 2016-10-29 | 1 | -1920/+0 |
* | porting: Fix code-block markup | Joel Sherrill | 2016-10-27 | 7 | -71/+71 |
* | rtems-docs: Fix many unnecessary back slashes | Joel Sherrill | 2016-10-27 | 5 | -64/+64 |
* | Set SPDX License Identifier in each source file. | Chris Johns | 2016-05-20 | 14 | -0/+28 |
* | Add PDF generation support use with --pdf | Amar Takhar | 2016-05-02 | 2 | -6/+5 |
* | Add support for spellchecking with a custom dictionary. | Amar Takhar | 2016-05-02 | 1 | -1/+1 |
| | | | | | | | | | | | | | | To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar. | ||||
* | Convert all Unicode to ASCII(128) | Amar Takhar | 2016-05-02 | 9 | -22/+22 |
* | Rework how conf.py is handled. | Amar Takhar | 2016-05-02 | 2 | -9/+9 |
| | | | | Needed to switch due to increasing complexity. | ||||
* | Rename old document for reference only. | Amar Takhar | 2016-05-02 | 1 | -0/+0 |
* | Split document into seperate files by section. | Amar Takhar | 2016-05-02 | 13 | -1/+1858 |
* | Fix markup | Amar Takhar | 2016-05-02 | 1 | -0/+2 |
* | Initial reST documentation using Sphinx. | Amar Takhar | 2016-05-02 | 3 | -0/+1936 |
