path: root/porting/index.rst (follow)
* Add common header.rst to reduce copy and pasteSebastian Huber2019-01-091-23/+1
* Update the copyright year.Chris Johns2018-10-191-1/+1
* build: Fix indexing so it works on HTML and PDF.Chris Johns2018-08-211-1/+1
| | | | | | | | | | | | - Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503
* Add indexes to all documents.Chris Johns2017-11-121-2/+1
| | | | Update #3229.
* Update copyright notices.Chris Johns2017-08-111-29/+33
* Update document titles for consistencyJoel Sherrill2017-01-111-3/+3
* Set SPDX License Identifier in each source file.Chris Johns2016-05-201-0/+2
* Convert all Unicode to ASCII(128)Amar Takhar2016-05-021-1/+1
* Split document into seperate files by section.Amar Takhar2016-05-021-1/+52
* Initial reST documentation using Sphinx.Amar Takhar2016-05-021-0/+1
