path: root/networking (follow)
* Remove the old files.Chris Johns2016-10-291-2044/+0
* dec_21140.rst, network_task_structure.rst: Change image to figureJoel Sherrill2016-10-282-6/+9
* dec_21140.rst: Correct path to imageJoel Sherrill2016-10-281-1/+1
* rtems-docs: Fix many unnecessary back slashesJoel Sherrill2016-10-271-4/+4
* Set SPDX License Identifier in each source file.Chris Johns2016-05-2010-0/+20
* Move images to a common directory.Amar Takhar2016-05-185-3/+3
* Fix indenting.Chris Johns2016-05-021-2/+1
* Clean up and review of Networking User Guide.Chris Johns2016-05-029-1205/+1134
* Add 'waf linkcheck' to check external references.Amar Takhar2016-05-021-1/+1
* Add PDF generation support use with --pdfAmar Takhar2016-05-022-6/+5
* Add support for spellchecking with a custom dictionary.Amar Takhar2016-05-021-1/+1
| | | | | | | | | | | | | | To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar.
* Convert all Unicode to ASCII(128)Amar Takhar2016-05-028-45/+45
* Rework how conf.py is handled.Amar Takhar2016-05-022-9/+9
| | | | Needed to switch due to increasing complexity.
* Move preface/intro one level up so the section is unnumbered.Amar Takhar2016-05-021-1/+2
* Split document.Amar Takhar2016-05-0210-1/+1992
* Fix markupAmar Takhar2016-05-021-6/+47
* Fix images.Amar Takhar2016-05-024-12/+3
* Initial reST documentation using Sphinx.Amar Takhar2016-05-023-0/+2030
