path: root/networking (unfollow)
2018-10-19Update the copyright year.Chris Johns1-1/+1
2018-08-21build: Fix indexing so it works on HTML and PDF.Chris Johns2-5/+1
- Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503
2018-04-27Update due to BSP source reorganizationSebastian Huber1-1/+1
This patch is a part of the BSP source reorganization. Close #3285.
2017-11-12Add indexes to all documents.Chris Johns2-2/+5
Update #3229.
2017-08-11Update copyright notices.Chris Johns1-2/+8
2017-03-27waf: Cleaner formatting to see the importing.Chris Johns1-2/+7
2017-03-20Use a single top level version number.Chris Johns1-4/+5
2017-01-11Update document titles for consistencyJoel Sherrill2-4/+4
2016-12-21Update version/revision to 4.11.99Sebastian Huber1-2/+2
2016-10-29Remove the old files.Chris Johns1-2044/+0
2016-10-28dec_21140.rst, network_task_structure.rst: Change image to figureJoel Sherrill2-6/+9
2016-10-28dec_21140.rst: Correct path to imageJoel Sherrill1-1/+1
2016-10-27rtems-docs: Fix many unnecessary back slashesJoel Sherrill1-4/+4
2016-05-20Set SPDX License Identifier in each source file.Chris Johns10-0/+20
2016-05-18Move images to a common directory.Amar Takhar5-3/+3
2016-05-02Fix indenting.Chris Johns1-2/+1
2016-05-02Clean up and review of Networking User Guide.Chris Johns9-1205/+1134
2016-05-02Add 'waf linkcheck' to check external references.Amar Takhar1-1/+1
2016-05-02Add PDF generation support use with --pdfAmar Takhar2-6/+5
2016-05-02Add support for spellchecking with a custom dictionary.Amar Takhar1-1/+1
To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar.
2016-05-02Convert all Unicode to ASCII(128)Amar Takhar8-45/+45
2016-05-02Rework how conf.py is handled.Amar Takhar2-9/+9
Needed to switch due to increasing complexity.
2016-05-02Move preface/intro one level up so the section is unnumbered.Amar Takhar1-1/+2
2016-05-02Split document.Amar Takhar10-1/+1992
2016-05-02Fix markupAmar Takhar1-6/+47
2016-05-02Fix images.Amar Takhar4-12/+3
