path: root/networking (follow)
* Address several issues from compiling examplesMartin Erik Werner2019-09-033-7/+13
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Compiling the code from examples "code-block:: c" along with public includes and a bsp exposed a few issues amongst a lot of false positives. Address some of these: * Terminate struct declarations with ';'. Mainly for pedantic correctness. * Show ptrdiff_t instead of size_t for the sbrk() prototype, matching the current argument type in rtems. * Replace some occurrences of unsigned16 with uint16_t. * Fix odd type declaration, "uint8_t char*" -> "char*". * Use appropriate helper to get chain head instead of invalid access to nonexistent struct member. * Remove several excess '\' escapes. * Use RTEMS_SELF instead of undefined SELF. * Use rtems_task instead of void for task functions. * Add missing stack size parameter in task creation. * Use rtems_interrupt_level instead of undefined rtems_interrupt. * Correct return value format for rtems_object_id_get_api() rtems_object_id_get_index() (enum and uint16_t) and also fix corresponding print formatting. * Correct return value documentation for rtems_object_id_get_class(), rtems_object_id_get_node() and rtems_object_id_get_index() int -> uint32_t. * Use RTEMS_SUCCESSFUL instead of undefined RTEMS_STATUS_SUCCESSFUL and fix return value variable name in rate monotonic examples. * Use RTEMS_TIMEOUT instead of undefined TIMEOUT and RTEMS_PERIOD_STATUS instead of undefined STATUS. * Add missing fields to ftpd configuration. * Correct parameter types in ftpd hook prototype, unsigned char * -> void *. * Fix various code-block:: attributes, c -> makefile and c -> shell. * Add missing parenthesis in socket buffer memory calculation example. * Remove typedef in declaration of mq_attr since it is defiend without typedef in reality. * Update siginfo_t declaration to match current reality. * Update shell user command definition example to include mode, uid and gid.
* Add unicode support for commonly used characters like copyright.Chris Johns2019-02-281-2/+4
| | | | | - This change makes the copyright character easier to see on editors lacking good unicode rendering support, ie terminals.
* Use pathto() on the genindex URL to make it relative.Chris Johns2019-02-151-2/+0
* waf: Remove as many sys path hacks as we can.Chris Johns2019-02-131-11/+7
| | | | | | | | There are still sys.path hacks in the conf.py files. They cannot be removed because the instance of python running the sphinx-build command does not see our top level path hacks. I looked at using PYTHONPATH but I could not figure out how to set a process environ var for a waf build instance.
* build: Prepend project common pathSebastian Huber2019-02-082-2/+2
| | | | | This avoids conflicts with standard packages such as PIL (Python Imaging Library).
* Reformat and update copyright and license noticesSebastian Huber2019-01-141-8/+6
| | | | | | | | For everything before 2015 an OAR copyright is assumed. Later copyright notices are based on Git commits on a best effort basis. The copyright notices of the "RTEMS Software Engineering Handbook" and the "RTEMS CPU Architecture Supplement" are incomplete.
* Simplify SPDX-License-Identifier commentSebastian Huber2019-01-119-9/+9
* Remove superfluous "All rights reserved."Sebastian Huber2019-01-115-5/+0
* Use standard format for copyright linesSebastian Huber2019-01-115-10/+5
* Add common header.rst to reduce copy and pasteSebastian Huber2019-01-091-23/+1
* Integrate images redrawn as part of GCI 2018Marçal Comajoan Cara2018-12-112-3/+3
| | | | | | | All of the redrawings were made by me except images/c_user/states which was made by LukaMag. This patch serves to update all the images. This work was part of GCI 2018.
* Update the copyright year.Chris Johns2018-10-191-1/+1
* build: Fix indexing so it works on HTML and PDF.Chris Johns2018-08-212-5/+1
| | | | | | | | | | | | - Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503
* Update due to BSP source reorganizationSebastian Huber2018-04-271-1/+1
| | | | | | This patch is a part of the BSP source reorganization. Close #3285.
* Add indexes to all documents.Chris Johns2017-11-122-2/+5
| | | | Update #3229.
* Update copyright notices.Chris Johns2017-08-111-2/+8
* waf: Cleaner formatting to see the importing.Chris Johns2017-03-271-2/+7
* Use a single top level version number.Chris Johns2017-03-201-4/+5
* Update document titles for consistencyJoel Sherrill2017-01-112-4/+4
* Update version/revision to 4.11.99Sebastian Huber2016-12-211-2/+2
* Remove the old files.Chris Johns2016-10-291-2044/+0
* dec_21140.rst, network_task_structure.rst: Change image to figureJoel Sherrill2016-10-282-6/+9
* dec_21140.rst: Correct path to imageJoel Sherrill2016-10-281-1/+1
* rtems-docs: Fix many unnecessary back slashesJoel Sherrill2016-10-271-4/+4
* Set SPDX License Identifier in each source file.Chris Johns2016-05-2010-0/+20
* Move images to a common directory.Amar Takhar2016-05-185-3/+3
* Fix indenting.Chris Johns2016-05-021-2/+1
* Clean up and review of Networking User Guide.Chris Johns2016-05-029-1205/+1134
* Add 'waf linkcheck' to check external references.Amar Takhar2016-05-021-1/+1
* Add PDF generation support use with --pdfAmar Takhar2016-05-022-6/+5
* Add support for spellchecking with a custom dictionary.Amar Takhar2016-05-021-1/+1
| | | | | | | | | | | | | | To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar.
* Convert all Unicode to ASCII(128)Amar Takhar2016-05-028-45/+45
* Rework how conf.py is handled.Amar Takhar2016-05-022-9/+9
| | | | Needed to switch due to increasing complexity.
* Move preface/intro one level up so the section is unnumbered.Amar Takhar2016-05-021-1/+2
* Split document.Amar Takhar2016-05-0210-1/+1992
* Fix markupAmar Takhar2016-05-021-6/+47
* Fix images.Amar Takhar2016-05-024-12/+3
* Initial reST documentation using Sphinx.Amar Takhar2016-05-023-0/+2030
