* | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 2018-08-21 | 2 | -5/+1 |
| | | | | | | | | | | | | - Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | ||||
* | Update due to BSP source reorganization | Sebastian Huber | 2018-04-27 | 1 | -1/+1 |
| | | | | | | This patch is a part of the BSP source reorganization. Close #3285. | ||||
* | Add indexes to all documents. | Chris Johns | 2017-11-12 | 2 | -2/+5 |
| | | | | Update #3229. | ||||
* | Update copyright notices. | Chris Johns | 2017-08-11 | 1 | -2/+8 |
* | waf: Cleaner formatting to see the importing. | Chris Johns | 2017-03-27 | 1 | -2/+7 |
* | Use a single top level version number. | Chris Johns | 2017-03-20 | 1 | -4/+5 |
* | Update document titles for consistency | Joel Sherrill | 2017-01-11 | 2 | -4/+4 |
* | Update version/revision to 4.11.99 | Sebastian Huber | 2016-12-21 | 1 | -2/+2 |
* | Remove the old files. | Chris Johns | 2016-10-29 | 1 | -2044/+0 |
* | dec_21140.rst, network_task_structure.rst: Change image to figure | Joel Sherrill | 2016-10-28 | 2 | -6/+9 |
* | dec_21140.rst: Correct path to image | Joel Sherrill | 2016-10-28 | 1 | -1/+1 |
* | rtems-docs: Fix many unnecessary back slashes | Joel Sherrill | 2016-10-27 | 1 | -4/+4 |
* | Set SPDX License Identifier in each source file. | Chris Johns | 2016-05-20 | 10 | -0/+20 |
* | Move images to a common directory. | Amar Takhar | 2016-05-18 | 5 | -3/+3 |
* | Fix indenting. | Chris Johns | 2016-05-02 | 1 | -2/+1 |
* | Clean up and review of Networking User Guide. | Chris Johns | 2016-05-02 | 9 | -1205/+1134 |
* | Add 'waf linkcheck' to check external references. | Amar Takhar | 2016-05-02 | 1 | -1/+1 |
* | Add PDF generation support use with --pdf | Amar Takhar | 2016-05-02 | 2 | -6/+5 |
* | Add support for spellchecking with a custom dictionary. | Amar Takhar | 2016-05-02 | 1 | -1/+1 |
| | | | | | | | | | | | | | | To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar. | ||||
* | Convert all Unicode to ASCII(128) | Amar Takhar | 2016-05-02 | 8 | -45/+45 |
* | Rework how conf.py is handled. | Amar Takhar | 2016-05-02 | 2 | -9/+9 |
| | | | | Needed to switch due to increasing complexity. | ||||
* | Move preface/intro one level up so the section is unnumbered. | Amar Takhar | 2016-05-02 | 1 | -1/+2 |
* | Split document. | Amar Takhar | 2016-05-02 | 10 | -1/+1992 |
* | Fix markup | Amar Takhar | 2016-05-02 | 1 | -6/+47 |
* | Fix images. | Amar Takhar | 2016-05-02 | 4 | -12/+3 |
* | Initial reST documentation using Sphinx. | Amar Takhar | 2016-05-02 | 3 | -0/+2030 |
