* | rtems-docs: Fix many unnecessary back slashes | Joel Sherrill | 2016-10-27 | 1 | -4/+4 |
* | Set SPDX License Identifier in each source file. | Chris Johns | 2016-05-20 | 10 | -0/+20 |
* | Move images to a common directory. | Amar Takhar | 2016-05-18 | 5 | -3/+3 |
* | Fix indenting. | Chris Johns | 2016-05-02 | 1 | -2/+1 |
* | Clean up and review of Networking User Guide. | Chris Johns | 2016-05-02 | 9 | -1205/+1134 |
* | Add 'waf linkcheck' to check external references. | Amar Takhar | 2016-05-02 | 1 | -1/+1 |
* | Add PDF generation support use with --pdf | Amar Takhar | 2016-05-02 | 2 | -6/+5 |
* | Add support for spellchecking with a custom dictionary. | Amar Takhar | 2016-05-02 | 1 | -1/+1 |
| | | | | | | | | | | | | | | To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar. | ||||
* | Convert all Unicode to ASCII(128) | Amar Takhar | 2016-05-02 | 8 | -45/+45 |
* | Rework how conf.py is handled. | Amar Takhar | 2016-05-02 | 2 | -9/+9 |
| | | | | Needed to switch due to increasing complexity. | ||||
* | Move preface/intro one level up so the section is unnumbered. | Amar Takhar | 2016-05-02 | 1 | -1/+2 |
* | Split document. | Amar Takhar | 2016-05-02 | 10 | -1/+1992 |
* | Fix markup | Amar Takhar | 2016-05-02 | 1 | -6/+47 |
* | Fix images. | Amar Takhar | 2016-05-02 | 4 | -12/+3 |
* | Initial reST documentation using Sphinx. | Amar Takhar | 2016-05-02 | 3 | -0/+2030 |
