path: root/networking/network_servers.rst (follow)
* Address several issues from compiling examplesMartin Erik Werner2019-09-031-2/+8
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Compiling the code from examples "code-block:: c" along with public includes and a bsp exposed a few issues amongst a lot of false positives. Address some of these: * Terminate struct declarations with ';'. Mainly for pedantic correctness. * Show ptrdiff_t instead of size_t for the sbrk() prototype, matching the current argument type in rtems. * Replace some occurrences of unsigned16 with uint16_t. * Fix odd type declaration, "uint8_t char*" -> "char*". * Use appropriate helper to get chain head instead of invalid access to nonexistent struct member. * Remove several excess '\' escapes. * Use RTEMS_SELF instead of undefined SELF. * Use rtems_task instead of void for task functions. * Add missing stack size parameter in task creation. * Use rtems_interrupt_level instead of undefined rtems_interrupt. * Correct return value format for rtems_object_id_get_api() rtems_object_id_get_index() (enum and uint16_t) and also fix corresponding print formatting. * Correct return value documentation for rtems_object_id_get_class(), rtems_object_id_get_node() and rtems_object_id_get_index() int -> uint32_t. * Use RTEMS_SUCCESSFUL instead of undefined RTEMS_STATUS_SUCCESSFUL and fix return value variable name in rate monotonic examples. * Use RTEMS_TIMEOUT instead of undefined TIMEOUT and RTEMS_PERIOD_STATUS instead of undefined STATUS. * Add missing fields to ftpd configuration. * Correct parameter types in ftpd hook prototype, unsigned char * -> void *. * Fix various code-block:: attributes, c -> makefile and c -> shell. * Add missing parenthesis in socket buffer memory calculation example. * Remove typedef in declaration of mq_attr since it is defiend without typedef in reality. * Update siginfo_t declaration to match current reality. * Update shell user command definition example to include mode, uid and gid.
* Simplify SPDX-License-Identifier commentSebastian Huber2019-01-111-1/+1
* Set SPDX License Identifier in each source file.Chris Johns2016-05-201-0/+2
* Clean up and review of Networking User Guide.Chris Johns2016-05-021-43/+42
* Convert all Unicode to ASCII(128)Amar Takhar2016-05-021-1/+1
* Split document.Amar Takhar2016-05-021-0/+109
