2023-08-09 | Add Regulator documentation based on V1 functionality | Joel Sherrill | 2 | -0/+16 | |
2023-05-20 | Update company name | Sebastian Huber | 8 | -8/+8 | |
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | |||||
2022-10-14 | TFTPFS: Adding missing diagram | Frank Kühndel | 2 | -0/+37 | |
2021-07-06 | rtems-docs: remove Eclipse Manual | Ray Garza | 28 | -0/+0 | |
Due to RTEMS 6 no longer using the Make build system and instead using Waf (Eclipse does not offer Waf support), this guide is being removed. | |||||
2020-10-19 | user/beagle: Add debug hardware mod | Chris Johns | 1 | -0/+0 | |
2020-10-08 | images: Fix bld-deps.png size | Sebastian Huber | 3 | -1/+1 | |
2020-09-19 | eng: Improve interrupt test image | Sebastian Huber | 3 | -0/+0 | |
2020-09-13 | eng: Add BSP build system chapter | Sebastian Huber | 12 | -0/+212 | |
Update #3818. | |||||
2020-07-23 | eng: Update test framework chapter | Sebastian Huber | 3 | -0/+0 | |
Document the dynamic text fixtures, utility functions, and the interrupt test support. Reorder some sections and reword some paragraphs based on review comments. Update #3199. | |||||
2020-05-05 | eng: Update requirements engineering chapter | Sebastian Huber | 6 | -17/+18 | |
Update requirements engineering chapter due to the removal of Doorstop as the requirements management tool. Update the application configuration related specification items. Update #3715. | |||||
2020-02-18 | user/tools: Add RTEMS TFTP Proxy command documentation | Chris Johns | 2 | -0/+34 | |
2020-01-07 | eng: Add Software Requirements Engineering chapter | Sebastian Huber | 9 | -0/+134 | |
2019-10-30 | user: Document patch review process | Sebastian Huber | 2 | -0/+48 | |
2019-02-20 | user: Add a Dynamic Loader section. | Chris Johns | 4 | -0/+81 | |
2019-02-13 | waf: Remove as many sys path hacks as we can. | Chris Johns | 1 | -7/+3 | |
There are still sys.path hacks in the conf.py files. They cannot be removed because the instance of python running the sphinx-build command does not see our top level path hacks. I looked at using PYTHONPATH but I could not figure out how to set a process environ var for a waf build instance. | |||||
2019-02-08 | build: Prepend project common path | Sebastian Huber | 1 | -1/+1 | |
This avoids conflicts with standard packages such as PIL (Python Imaging Library). | |||||
2018-12-17 | images/eng/Git-personalrepo: Redrawn image (GCI 2018) | Marçal Comajoan Cara | 2 | -0/+33 | |
Redraw images/eng/Git-personalrepo as SVG and PNG with a better color palette. | |||||
2018-12-17 | eng/vc-authors: Convert wiki page to Rest (GCI 2018) | Marçal Comajoan Cara | 1 | -0/+0 | |
Converted https://devel.rtems.org/wiki/Developer/Git/Committers to Rest, and TBDs and wiki TODOs into comments. Also changed http links to https (the ones that are possible), corrected some typos, created a folder for eng images and added some formatting. This work was part of GCI 2018. | |||||
2018-12-11 | Integrate images redrawn as part of GCI 2018 | Marçal Comajoan Cara | 23 | -0/+814 | |
All of the redrawings were made by me except images/c_user/states which was made by LukaMag. This patch serves to update all the images. This work was part of GCI 2018. | |||||
2018-11-19 | images/cpu_supplement/sparcwin.svg: New file (GCI 2018) | Marçal Comajoan Cara | 1 | -0/+176 | |
File was missed in previous commit. | |||||
2018-11-19 | Improve SPARC Calling Overview Webpage conversion | Marçal Comajoan Cara | 5 | -0/+112 | |
Fixed tables, typos, redrawn images and converted ASCII art to ditaa and PNG, and improved the overall format. This work was part of GCI 2018. Closes #3567. | |||||
2018-11-03 | user: Add RTEMS executable test generated images. | Chris Johns | 15 | -0/+0 | |
2018-11-03 | user: Add RTEMS executable and test documentation. | Chris Johns | 15 | -0/+522 | |
2018-11-03 | waf: Add support to build PlantUML and Ditaa images. | Chris Johns | 2 | -0/+8 | |
2018-06-18 | Adding Trace Docuemntation Images | Vidushi Vashishth | 2 | -0/+0 | |
-Removed CTF related images | |||||
2017-02-02 | c-user: Add SMP low-level synchronization | Sebastian Huber | 4 | -0/+0 | |
2016-10-29 | user: Add hardware layers figure. | Chris Johns | 1 | -0/+0 | |
2016-05-20 | Add Eclipse user manual for RTEMS. | Chris Johns | 28 | -0/+0 | |
2016-05-18 | Move images to a common directory. | Amar Takhar | 8 | -0/+0 | |
