2019-02-20 | user: Add a Dynamic Loader section. | Chris Johns | 4 | -0/+81 | |
2019-02-13 | waf: Remove as many sys path hacks as we can. | Chris Johns | 1 | -7/+3 | |
There are still sys.path hacks in the conf.py files. They cannot be removed because the instance of python running the sphinx-build command does not see our top level path hacks. I looked at using PYTHONPATH but I could not figure out how to set a process environ var for a waf build instance. | |||||
2019-02-08 | build: Prepend project common path | Sebastian Huber | 1 | -1/+1 | |
This avoids conflicts with standard packages such as PIL (Python Imaging Library). | |||||
2018-12-17 | images/eng/Git-personalrepo: Redrawn image (GCI 2018) | Marçal Comajoan Cara | 2 | -0/+33 | |
Redraw images/eng/Git-personalrepo as SVG and PNG with a better color palette. | |||||
2018-12-17 | eng/vc-authors: Convert wiki page to Rest (GCI 2018) | Marçal Comajoan Cara | 1 | -0/+0 | |
Converted https://devel.rtems.org/wiki/Developer/Git/Committers to Rest, and TBDs and wiki TODOs into comments. Also changed http links to https (the ones that are possible), corrected some typos, created a folder for eng images and added some formatting. This work was part of GCI 2018. | |||||
2018-12-11 | Integrate images redrawn as part of GCI 2018 | Marçal Comajoan Cara | 23 | -0/+814 | |
All of the redrawings were made by me except images/c_user/states which was made by LukaMag. This patch serves to update all the images. This work was part of GCI 2018. | |||||
2018-11-19 | images/cpu_supplement/sparcwin.svg: New file (GCI 2018) | Marçal Comajoan Cara | 1 | -0/+176 | |
File was missed in previous commit. | |||||
2018-11-19 | Improve SPARC Calling Overview Webpage conversion | Marçal Comajoan Cara | 5 | -0/+112 | |
Fixed tables, typos, redrawn images and converted ASCII art to ditaa and PNG, and improved the overall format. This work was part of GCI 2018. Closes #3567. | |||||
2018-11-03 | user: Add RTEMS executable test generated images. | Chris Johns | 15 | -0/+0 | |
2018-11-03 | user: Add RTEMS executable and test documentation. | Chris Johns | 15 | -0/+522 | |
2018-11-03 | waf: Add support to build PlantUML and Ditaa images. | Chris Johns | 2 | -0/+8 | |
2018-06-18 | Adding Trace Docuemntation Images | Vidushi Vashishth | 2 | -0/+0 | |
-Removed CTF related images | |||||
2017-02-02 | c-user: Add SMP low-level synchronization | Sebastian Huber | 4 | -0/+0 | |
2016-10-29 | user: Add hardware layers figure. | Chris Johns | 1 | -0/+0 | |
2016-05-20 | Add Eclipse user manual for RTEMS. | Chris Johns | 28 | -0/+0 | |
2016-05-18 | Move images to a common directory. | Amar Takhar | 8 | -0/+0 | |
