* | user: Document patch review process | Sebastian Huber | 2019-10-30 | 2 | -0/+48 |
* | user: Add a Dynamic Loader section. | Chris Johns | 2019-02-20 | 4 | -0/+81 |
* | waf: Remove as many sys path hacks as we can. | Chris Johns | 2019-02-13 | 1 | -7/+3 |
| | | | | | | | | There are still sys.path hacks in the conf.py files. They cannot be removed because the instance of python running the sphinx-build command does not see our top level path hacks. I looked at using PYTHONPATH but I could not figure out how to set a process environ var for a waf build instance. | ||||
* | build: Prepend project common path | Sebastian Huber | 2019-02-08 | 1 | -1/+1 |
| | | | | | This avoids conflicts with standard packages such as PIL (Python Imaging Library). | ||||
* | images/eng/Git-personalrepo: Redrawn image (GCI 2018) | Marçal Comajoan Cara | 2018-12-17 | 2 | -0/+33 |
| | | | | | Redraw images/eng/Git-personalrepo as SVG and PNG with a better color palette. | ||||
* | eng/vc-authors: Convert wiki page to Rest (GCI 2018) | Marçal Comajoan Cara | 2018-12-17 | 1 | -0/+0 |
| | | | | | | | | | Converted https://devel.rtems.org/wiki/Developer/Git/Committers to Rest, and TBDs and wiki TODOs into comments. Also changed http links to https (the ones that are possible), corrected some typos, created a folder for eng images and added some formatting. This work was part of GCI 2018. | ||||
* | Integrate images redrawn as part of GCI 2018 | Marçal Comajoan Cara | 2018-12-11 | 23 | -0/+814 |
| | | | | | | | All of the redrawings were made by me except images/c_user/states which was made by LukaMag. This patch serves to update all the images. This work was part of GCI 2018. | ||||
* | images/cpu_supplement/sparcwin.svg: New file (GCI 2018) | Marçal Comajoan Cara | 2018-11-19 | 1 | -0/+176 |
| | | | | File was missed in previous commit. | ||||
* | Improve SPARC Calling Overview Webpage conversion | Marçal Comajoan Cara | 2018-11-19 | 5 | -0/+112 |
| | | | | | | | | | Fixed tables, typos, redrawn images and converted ASCII art to ditaa and PNG, and improved the overall format. This work was part of GCI 2018. Closes #3567. | ||||
* | user: Add RTEMS executable test generated images. | Chris Johns | 2018-11-03 | 15 | -0/+0 |
* | user: Add RTEMS executable and test documentation. | Chris Johns | 2018-11-03 | 15 | -0/+522 |
* | waf: Add support to build PlantUML and Ditaa images. | Chris Johns | 2018-11-03 | 2 | -0/+8 |
* | Adding Trace Docuemntation Images | Vidushi Vashishth | 2018-06-18 | 2 | -0/+0 |
| | | | | -Removed CTF related images | ||||
* | c-user: Add SMP low-level synchronization | Sebastian Huber | 2017-02-02 | 4 | -0/+0 |
* | user: Add hardware layers figure. | Chris Johns | 2016-10-29 | 1 | -0/+0 |
* | Add Eclipse user manual for RTEMS. | Chris Johns | 2016-05-20 | 28 | -0/+0 |
* | Move images to a common directory. | Amar Takhar | 2016-05-18 | 8 | -0/+0 |
