path: root/images (follow)
* user/beagle: Add debug hardware modChris Johns2020-10-191-0/+0
* images: Fix bld-deps.png sizeSebastian Huber2020-10-083-1/+1
* eng: Improve interrupt test imageSebastian Huber2020-09-193-0/+0
* eng: Add BSP build system chapterSebastian Huber2020-09-1312-0/+212
| | | | Update #3818.
* eng: Update test framework chapterSebastian Huber2020-07-233-0/+0
| | | | | | | | Document the dynamic text fixtures, utility functions, and the interrupt test support. Reorder some sections and reword some paragraphs based on review comments. Update #3199.
* eng: Update requirements engineering chapterSebastian Huber2020-05-056-17/+18
| | | | | | | | | Update requirements engineering chapter due to the removal of Doorstop as the requirements management tool. Update the application configuration related specification items. Update #3715.
* user/tools: Add RTEMS TFTP Proxy command documentationChris Johns2020-02-182-0/+34
* eng: Add Software Requirements Engineering chapterSebastian Huber2020-01-079-0/+134
| | | | Update #3715.
* user: Document patch review processSebastian Huber2019-10-302-0/+48
* user: Add a Dynamic Loader section.Chris Johns2019-02-204-0/+81
* waf: Remove as many sys path hacks as we can.Chris Johns2019-02-131-7/+3
| | | | | | | | There are still sys.path hacks in the conf.py files. They cannot be removed because the instance of python running the sphinx-build command does not see our top level path hacks. I looked at using PYTHONPATH but I could not figure out how to set a process environ var for a waf build instance.
* build: Prepend project common pathSebastian Huber2019-02-081-1/+1
| | | | | This avoids conflicts with standard packages such as PIL (Python Imaging Library).
* images/eng/Git-personalrepo: Redrawn image (GCI 2018)Marçal Comajoan Cara2018-12-172-0/+33
| | | | | Redraw images/eng/Git-personalrepo as SVG and PNG with a better color palette.
* eng/vc-authors: Convert wiki page to Rest (GCI 2018)Marçal Comajoan Cara2018-12-171-0/+0
| | | | | | | | | Converted https://devel.rtems.org/wiki/Developer/Git/Committers to Rest, and TBDs and wiki TODOs into comments. Also changed http links to https (the ones that are possible), corrected some typos, created a folder for eng images and added some formatting. This work was part of GCI 2018.
* Integrate images redrawn as part of GCI 2018Marçal Comajoan Cara2018-12-1123-0/+814
| | | | | | | All of the redrawings were made by me except images/c_user/states which was made by LukaMag. This patch serves to update all the images. This work was part of GCI 2018.
* images/cpu_supplement/sparcwin.svg: New file (GCI 2018)Marçal Comajoan Cara2018-11-191-0/+176
| | | | File was missed in previous commit.
* Improve SPARC Calling Overview Webpage conversionMarçal Comajoan Cara2018-11-195-0/+112
| | | | | | | | | Fixed tables, typos, redrawn images and converted ASCII art to ditaa and PNG, and improved the overall format. This work was part of GCI 2018. Closes #3567.
* user: Add RTEMS executable test generated images.Chris Johns2018-11-0315-0/+0
* user: Add RTEMS executable and test documentation.Chris Johns2018-11-0315-0/+522
* waf: Add support to build PlantUML and Ditaa images.Chris Johns2018-11-032-0/+8
* Adding Trace Docuemntation ImagesVidushi Vashishth2018-06-182-0/+0
| | | | -Removed CTF related images
* c-user: Add SMP low-level synchronizationSebastian Huber2017-02-024-0/+0
* user: Add hardware layers figure.Chris Johns2016-10-291-0/+0
* Add Eclipse user manual for RTEMS.Chris Johns2016-05-2028-0/+0
* Move images to a common directory.Amar Takhar2016-05-188-0/+0
