2016-10-28 | filesystem: Fix numbered lists. | Joel Sherrill | 1 | -39/+39 | |
2016-10-28 | in-memory.rst, mounting_and_unmounting.rst: Remove unnecessary backslash | Joel Sherrill | 2 | -2/+2 | |
2016-10-29 | Remove the old files. | Chris Johns | 1 | -4602/+0 | |
2016-10-27 | Fix filesystem formatting. | Chris Johns | 11 | -1404/+1165 | |
2016-05-20 | Set SPDX License Identifier in each source file. | Chris Johns | 12 | -0/+24 | |
2016-05-02 | Add 'waf linkcheck' to check external references. | Amar Takhar | 1 | -1/+1 | |
2016-05-02 | Add support for singlehtml (inlined) HTML file, plus some other fixes. | Amar Takhar | 1 | -2/+1 | |
* This is still broken. * Rename sphinx_rtd_theme so it doesn't pickup locally installed ones * Add a hack to theme.css to get around inliner bug. * Some unrelated fixups in common/waf.py Unfortunatly several dozen fixes got merged into this. | |||||
2016-05-02 | Add PDF generation support use with --pdf | Amar Takhar | 2 | -6/+5 | |
2016-05-02 | Add support for spellchecking with a custom dictionary. | Amar Takhar | 1 | -1/+1 | |
To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar. | |||||
2016-05-02 | Convert all Unicode to ASCII(128) | Amar Takhar | 6 | -30/+30 | |
2016-05-02 | Rework how conf.py is handled. | Amar Takhar | 2 | -9/+9 | |
Needed to switch due to increasing complexity. | |||||
2016-05-02 | Fix section numbering, create TOC, seperate preface. | Amar Takhar | 2 | -58/+12 | |
2016-05-02 | Rename old document for reference only. | Amar Takhar | 1 | -0/+0 | |
2016-05-02 | Split document into seperate files by section. | Amar Takhar | 11 | -1/+4599 | |
2016-05-02 | Fix markup warnings. | Amar Takhar | 1 | -2/+21 | |
