* | Add unicode support for commonly used characters like copyright. | Chris Johns | 2019-02-28 | 1 | -1/+3 |
| | | | | | - This change makes the copyright character easier to see on editors lacking good unicode rendering support, ie terminals. | ||||
* | Use pathto() on the genindex URL to make it relative. | Chris Johns | 2019-02-15 | 1 | -2/+0 |
* | waf: Remove as many sys path hacks as we can. | Chris Johns | 2019-02-13 | 1 | -11/+7 |
| | | | | | | | | There are still sys.path hacks in the conf.py files. They cannot be removed because the instance of python running the sphinx-build command does not see our top level path hacks. I looked at using PYTHONPATH but I could not figure out how to set a process environ var for a waf build instance. | ||||
* | build: Prepend project common path | Sebastian Huber | 2019-02-08 | 2 | -2/+2 |
| | | | | | This avoids conflicts with standard packages such as PIL (Python Imaging Library). | ||||
* | Reformat and update copyright and license notices | Sebastian Huber | 2019-01-14 | 1 | -8/+5 |
| | | | | | | | | For everything before 2015 an OAR copyright is assumed. Later copyright notices are based on Git commits on a best effort basis. The copyright notices of the "RTEMS Software Engineering Handbook" and the "RTEMS CPU Architecture Supplement" are incomplete. | ||||
* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 11 | -11/+11 |
* | Remove superfluous "All rights reserved." | Sebastian Huber | 2019-01-11 | 8 | -8/+0 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 8 | -16/+8 |
* | Add common header.rst to reduce copy and paste | Sebastian Huber | 2019-01-09 | 1 | -23/+1 |
* | Update the copyright year. | Chris Johns | 2018-10-19 | 1 | -1/+1 |
* | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 2018-08-21 | 2 | -5/+1 |
| | | | | | | | | | | | | - Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | ||||
* | Add indexes to all documents. | Chris Johns | 2017-11-12 | 2 | -2/+5 |
| | | | | Update #3229. | ||||
* | Update copyright notices. | Chris Johns | 2017-08-11 | 1 | -5/+8 |
* | waf: Cleaner formatting to see the importing. | Chris Johns | 2017-03-27 | 1 | -2/+7 |
* | Use a single top level version number. | Chris Johns | 2017-03-20 | 1 | -4/+5 |
* | Update document titles for consistency | Joel Sherrill | 2017-01-11 | 1 | -3/+3 |
* | Update version/revision to 4.11.99 | Sebastian Huber | 2016-12-21 | 1 | -2/+2 |
* | filesystem: Fix header levels. | Chris Johns | 2016-11-09 | 12 | -2196/+1851 |
* | filesystem: Fix numbered lists. | Joel Sherrill | 2016-10-28 | 1 | -39/+39 |
* | in-memory.rst, mounting_and_unmounting.rst: Remove unnecessary backslash | Joel Sherrill | 2016-10-28 | 2 | -2/+2 |
* | Remove the old files. | Chris Johns | 2016-10-29 | 1 | -4602/+0 |
* | Fix filesystem formatting. | Chris Johns | 2016-10-27 | 11 | -1404/+1165 |
* | Set SPDX License Identifier in each source file. | Chris Johns | 2016-05-20 | 12 | -0/+24 |
* | Add 'waf linkcheck' to check external references. | Amar Takhar | 2016-05-02 | 1 | -1/+1 |
* | Add support for singlehtml (inlined) HTML file, plus some other fixes. | Amar Takhar | 2016-05-02 | 1 | -2/+1 |
| | | | | | | | | | * This is still broken. * Rename sphinx_rtd_theme so it doesn't pickup locally installed ones * Add a hack to theme.css to get around inliner bug. * Some unrelated fixups in common/waf.py Unfortunatly several dozen fixes got merged into this. | ||||
* | Add PDF generation support use with --pdf | Amar Takhar | 2016-05-02 | 2 | -6/+5 |
* | Add support for spellchecking with a custom dictionary. | Amar Takhar | 2016-05-02 | 1 | -1/+1 |
| | | | | | | | | | | | | | | To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar. | ||||
* | Convert all Unicode to ASCII(128) | Amar Takhar | 2016-05-02 | 6 | -30/+30 |
* | Rework how conf.py is handled. | Amar Takhar | 2016-05-02 | 2 | -9/+9 |
| | | | | Needed to switch due to increasing complexity. | ||||
* | Fix section numbering, create TOC, seperate preface. | Amar Takhar | 2016-05-02 | 2 | -58/+12 |
* | Rename old document for reference only. | Amar Takhar | 2016-05-02 | 1 | -0/+0 |
* | Split document into seperate files by section. | Amar Takhar | 2016-05-02 | 11 | -1/+4599 |
* | Fix markup warnings. | Amar Takhar | 2016-05-02 | 1 | -2/+21 |
* | Initial reST documentation using Sphinx. | Amar Takhar | 2016-05-02 | 3 | -0/+4601 |
