path: root/filesystem (unfollow)
2017-03-27waf: Cleaner formatting to see the importing.Chris Johns1-2/+7
2017-03-20Use a single top level version number.Chris Johns1-4/+5
2017-01-11Update document titles for consistencyJoel Sherrill1-3/+3
2016-12-21Update version/revision to 4.11.99Sebastian Huber1-2/+2
2016-11-09filesystem: Fix header levels.Chris Johns12-2196/+1851
2016-10-28filesystem: Fix numbered lists.Joel Sherrill1-39/+39
2016-10-28in-memory.rst, mounting_and_unmounting.rst: Remove unnecessary backslashJoel Sherrill2-2/+2
2016-10-29Remove the old files.Chris Johns1-4602/+0
2016-10-27Fix filesystem formatting.Chris Johns11-1404/+1165
2016-05-20Set SPDX License Identifier in each source file.Chris Johns12-0/+24
2016-05-02Add 'waf linkcheck' to check external references.Amar Takhar1-1/+1
2016-05-02Add support for singlehtml (inlined) HTML file, plus some other fixes.Amar Takhar1-2/+1
* This is still broken. * Rename sphinx_rtd_theme so it doesn't pickup locally installed ones * Add a hack to theme.css to get around inliner bug. * Some unrelated fixups in common/waf.py Unfortunatly several dozen fixes got merged into this.
2016-05-02Add PDF generation support use with --pdfAmar Takhar2-6/+5
2016-05-02Add support for spellchecking with a custom dictionary.Amar Takhar1-1/+1
To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar.
2016-05-02Convert all Unicode to ASCII(128)Amar Takhar6-30/+30
2016-05-02Rework how conf.py is handled.Amar Takhar2-9/+9
Needed to switch due to increasing complexity.
2016-05-02Fix section numbering, create TOC, seperate preface.Amar Takhar2-58/+12
2016-05-02Rename old document for reference only.Amar Takhar1-0/+0
2016-05-02Split document into seperate files by section.Amar Takhar11-1/+4599
2016-05-02Fix markup warnings.Amar Takhar1-2/+21
