* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 1 | -1/+1 |
* | Remove superfluous "All rights reserved." | Sebastian Huber | 2019-01-11 | 1 | -1/+0 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 1 | -2/+1 |
* | filesystem: Fix header levels. | Chris Johns | 2016-11-09 | 1 | -8/+7 |
* | Fix filesystem formatting. | Chris Johns | 2016-10-27 | 1 | -41/+35 |
* | Set SPDX License Identifier in each source file. | Chris Johns | 2016-05-20 | 1 | -0/+2 |
* | Fix section numbering, create TOC, seperate preface. | Amar Takhar | 2016-05-02 | 1 | -1/+2 |
* | Split document into seperate files by section. | Amar Takhar | 2016-05-02 | 1 | -0/+66 |
