* | Add common header.rst to reduce copy and paste | Sebastian Huber | 2019-01-09 | 1 | -23/+1 |
* | Update the copyright year. | Chris Johns | 2018-10-19 | 1 | -1/+1 |
* | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 2018-08-21 | 1 | -1/+1 |
| | | | | | | | | | | | | - Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | ||||
* | Add indexes to all documents. | Chris Johns | 2017-11-12 | 1 | -2/+1 |
| | | | | Update #3229. | ||||
* | Update copyright notices. | Chris Johns | 2017-08-11 | 1 | -5/+8 |
* | Update document titles for consistency | Joel Sherrill | 2017-01-11 | 1 | -3/+3 |
* | filesystem: Fix header levels. | Chris Johns | 2016-11-09 | 1 | -1/+4 |
* | Fix filesystem formatting. | Chris Johns | 2016-10-27 | 1 | -33/+28 |
* | Set SPDX License Identifier in each source file. | Chris Johns | 2016-05-20 | 1 | -0/+2 |
* | Convert all Unicode to ASCII(128) | Amar Takhar | 2016-05-02 | 1 | -1/+1 |
* | Fix section numbering, create TOC, seperate preface. | Amar Takhar | 2016-05-02 | 1 | -57/+10 |
* | Split document into seperate files by section. | Amar Takhar | 2016-05-02 | 1 | -1/+100 |
* | Initial reST documentation using Sphinx. | Amar Takhar | 2016-05-02 | 1 | -0/+1 |
