2019-02-08 | build: Prepend project common path | Sebastian Huber | 1 | -1/+1 | |
This avoids conflicts with standard packages such as PIL (Python Imaging Library). | |||||
2017-03-20 | Use a single top level version number. | Chris Johns | 1 | -4/+5 | |
2016-12-21 | Update version/revision to 4.11.99 | Sebastian Huber | 1 | -2/+2 | |
2016-11-09 | filesystem: Fix header levels. | Chris Johns | 1 | -3/+5 | |
2016-05-02 | Add support for singlehtml (inlined) HTML file, plus some other fixes. | Amar Takhar | 1 | -2/+1 | |
* This is still broken. * Rename sphinx_rtd_theme so it doesn't pickup locally installed ones * Add a hack to theme.css to get around inliner bug. * Some unrelated fixups in common/waf.py Unfortunatly several dozen fixes got merged into this. | |||||
2016-05-02 | Add PDF generation support use with --pdf | Amar Takhar | 1 | -0/+4 | |
2016-05-02 | Rework how conf.py is handled. | Amar Takhar | 1 | -0/+8 | |
Needed to switch due to increasing complexity. |
