2019-01-11 | Simplify SPDX-License-Identifier comment | Sebastian Huber | 1 | -1/+1 | |
2019-01-11 | Remove superfluous "All rights reserved." | Sebastian Huber | 1 | -1/+0 | |
2019-01-11 | Use standard format for copyright lines | Sebastian Huber | 1 | -2/+1 | |
2016-11-09 | filesystem: Fix header levels. | Chris Johns | 1 | -661/+604 | |
2016-10-28 | filesystem: Fix numbered lists. | Joel Sherrill | 1 | -39/+39 | |
2016-10-27 | Fix filesystem formatting. | Chris Johns | 1 | -427/+359 | |
2016-05-20 | Set SPDX License Identifier in each source file. | Chris Johns | 1 | -0/+2 | |
2016-05-02 | Convert all Unicode to ASCII(128) | Amar Takhar | 1 | -5/+5 | |
2016-05-02 | Split document into seperate files by section. | Amar Takhar | 1 | -0/+1132 | |
