2019-07-24 | eng: Add bibliography | Sebastian Huber | 2 | -0/+7 | |
2019-04-05 | eng: Rework Doxygen guidelines | Sebastian Huber | 1 | -441/+235 | |
Update #3704. | |||||
2019-04-04 | bsp-howto: Move BSP Doxygen recommendations | Sebastian Huber | 2 | -718/+0 | |
2019-03-27 | eng: Add software test framework chapter | Sebastian Huber | 2 | -0/+2255 | |
Update #3199. | |||||
2019-03-27 | eng: Change title to RTEMS Software Engineering | Sebastian Huber | 2 | -5/+5 | |
Use a shorter title so that the PDF page header fits into one line. | |||||
2019-03-13 | eng: Reformat | Sebastian Huber | 1 | -14/+14 | |
2019-02-28 | Add unicode support for commonly used characters like copyright. | Chris Johns | 1 | -1/+3 | |
- This change makes the copyright character easier to see on editors lacking good unicode rendering support, ie terminals. | |||||
2019-02-15 | Use pathto() on the genindex URL to make it relative. | Chris Johns | 1 | -2/+0 | |
2019-02-13 | waf: Remove as many sys path hacks as we can. | Chris Johns | 1 | -11/+7 | |
There are still sys.path hacks in the conf.py files. They cannot be removed because the instance of python running the sphinx-build command does not see our top level path hacks. I looked at using PYTHONPATH but I could not figure out how to set a process environ var for a waf build instance. | |||||
2019-02-08 | build: Prepend project common path | Sebastian Huber | 2 | -2/+2 | |
This avoids conflicts with standard packages such as PIL (Python Imaging Library). | |||||
2019-01-14 | Reformat and update copyright and license notices | Sebastian Huber | 1 | -8/+5 | |
For everything before 2015 an OAR copyright is assumed. Later copyright notices are based on Git commits on a best effort basis. The copyright notices of the "RTEMS Software Engineering Handbook" and the "RTEMS CPU Architecture Supplement" are incomplete. | |||||
2019-01-11 | Simplify SPDX-License-Identifier comment | Sebastian Huber | 28 | -28/+28 | |
2019-01-11 | Use standard format for copyright lines | Sebastian Huber | 28 | -35/+31 | |
2019-01-09 | Add common header.rst to reduce copy and paste | Sebastian Huber | 1 | -23/+1 | |
2018-12-20 | Eliminate UTF-8 characters except superscripted 2 in i2c | Joel Sherrill | 7 | -18/+18 | |
2018-12-20 | eng: Unicode char (U+200B) | Sebastian Huber | 1 | -3/+3 | |
2018-12-17 | eng/coding-conventions.rst: Convert TBD to Rest Format (GCI 2018) | Pritish Jain | 1 | -2/+244 | |
2018-12-17 | eng/coding-doxygen: Fix errors | Marçal Comajoan Cara | 1 | -352/+360 | |
This work was part of GCI 2018. | |||||
2018-12-17 | eng/coding-file-hdr.rst: Fix file formatting (GCI 2018) | Sal | 1 | -23/+25 | |
2018-12-17 | eng/coding-doxygen.rst: Clean up and make subsubsections | Joel Sherrill | 1 | -315/+362 | |
2018-12-17 | Converted Doxygen Best Practices Documentation to Rest format (GCI 2018) | zehata | 1 | -1/+417 | |
2018-12-17 | coding-naming: Convert TBD to Rest format (GCI 2018) | Pritish Jain | 1 | -2/+85 | |
2018-12-17 | eng/vc-users: Convert wiki page to Rest (GCI 2018) | Marçal Comajoan Cara | 1 | -2/+641 | |
Converted https://devel.rtems.org/wiki/Developer/Git/Users to Rest, and TBDs and wiki TODOs into comments. Also changed http links to https (the ones that are possible), corrected typos, updated learning resources links and added formattings. This work was part of GCI 2018. | |||||
2018-12-17 | eng/vc-authors: Convert wiki page to Rest (GCI 2018) | Marçal Comajoan Cara | 1 | -2/+353 | |
Converted https://devel.rtems.org/wiki/Developer/Git/Committers to Rest, and TBDs and wiki TODOs into comments. Also changed http links to https (the ones that are possible), corrected some typos, created a folder for eng images and added some formatting. This work was part of GCI 2018. | |||||
2018-12-17 | management: Convert TBD to rest Format (GCI 2018) | Pritiah Jain | 2 | -2/+154 | |
2018-12-17 | eng/conf.py: Use new short name of SW Eng Handbook | Marçal Comajoan Cara | 1 | -1/+1 | |
2018-12-17 | eng/license-requirements.rst: Add a TBD for BSD info | Joel Sherrill | 1 | -0/+1 | |
2018-12-17 | coding-doxygen-bsp.rst, coding-file-hdr.rst: Fix formatting | Joel Sherrill | 2 | -321/+651 | |
2018-12-17 | coding-file-hdr: Convert TBD to Rest Format (GCI 2018) | Pritish Jain | 1 | -3/+33 | |
2018-12-17 | coding-doxygen-bsp: Convert TBD to rest Format(GCI 2018) | Pritish Jain | 1 | -4/+384 | |
2018-12-17 | coding-gen-patch:Convert TBD to rest Format(GCI 2018) | Pritish Jain | 1 | -2/+27 | |
2018-12-17 | eng/coding-80cols: Convert wiki page to Rest | Marçal Comajoan Cara | 1 | -2/+146 | |
Converted https://devel.rtems.org/wiki/Developer/Coding/80_characters_per_line to Rest, and TBDs into comments. This work was part of GCI 2018. | |||||
2018-12-17 | eng/appendix-a: convert to a table | Marçal Comajoan Cara | 1 | -50/+106 | |
Convert text to a table, TBDs into comments and add missing formatting. This work was part of GCI 2018. | |||||
2018-12-17 | eng/test-suites.rst: Update to reflect current reality | Joel Sherrill | 1 | -6/+24 | |
2018-12-17 | test-suites:Convert TBD to rest Format(GCI 2018) | Pritish Jain | 1 | -3/+32 | |
2018-12-17 | Initial start of converting the Word outline to Rest | Joel Sherrill | 30 | -0/+649 | |
Thanks to Scott Zemerick <scott.zemerick@tmctechnologies.com> for the analysis and ideas that led to this. |
