* | eng: Clarify action requirement specification | Sebastian Huber | 2020-06-17 | 1 | -6/+136 |
| | | | | Update #3715. | ||||
* | eng: Update action requirement specification | Sebastian Huber | 2020-06-10 | 1 | -1/+80 |
* | eng: Update specification how-to section | Sebastian Huber | 2020-06-08 | 1 | -0/+75 |
* | eng: Add a specification type for actions | Sebastian Huber | 2020-06-08 | 1 | -24/+377 |
| | | | | | | | | | Add support to specify functional requirements for actions (functions or macros) via a transition map of pre-conditions to post-conditions. This will be the work horse for functional requirements. Generation of corresponding validation tests is supported. Update #3715. | ||||
* | eng: Add generic attribute key types | Sebastian Huber | 2020-06-04 | 1 | -26/+37 |
* | eng: Simplify wording for specification items | Sebastian Huber | 2020-06-04 | 1 | -247/+217 |
* | Use a complete sentence for acronym definitions | Sebastian Huber | 2020-06-04 | 1 | -10/+10 |
* | eng: Add interface specification how-to | Sebastian Huber | 2020-06-01 | 2 | -0/+89 |
* | eng: Update requirements tooling section | Sebastian Huber | 2020-05-29 | 1 | -11/+22 |
* | eng: Add generated documentation of spec items | Sebastian Huber | 2020-05-29 | 6 | -414/+4255 |
| | | | | | | | | | The documentation of the specification items is generated by an RTEMS qualification tool from a specification of specification items. Move non-generated content to "req-for-req.rst". Update #3715. | ||||
* | eng: Split up requirements engineering chapter | Sebastian Huber | 2020-05-29 | 9 | -1283/+1309 |
| | | | | | | | This allows to more easily generate the specification item section with a script using specification items. Update #3715. | ||||
* | eng: Update requirements engineering chapter | Sebastian Huber | 2020-05-05 | 1 | -304/+409 |
| | | | | | | | | | Update requirements engineering chapter due to the removal of Doorstop as the requirements management tool. Update the application configuration related specification items. Update #3715. | ||||
* | Rework RTEMS licensing discussions. | Joel Sherrill | 2020-05-01 | 2 | -14/+96 |
| | | | | | | | This now captures historical rationale along with cross-linking code templates with license guidelines. Closes #3962. | ||||
* | eng: Adjust config.h include | Sebastian Huber | 2020-04-15 | 1 | -1/+1 |
| | | | | Use variant used by most source files. | ||||
* | Add a release procedure section. | Chris Johns | 2020-04-04 | 2 | -3/+271 |
* | eng: Add documentation guidelines | Sebastian Huber | 2020-04-02 | 2 | -0/+80 |
| | | | | | | | | | Start with templates for the application configuration options. Remove "Format to be followed for making changes in this file" from c-user. Update #3910. | ||||
* | eng: Add glossary terms | Sebastian Huber | 2020-04-01 | 2 | -3/+92 |
| | | | | | | | | | | | | | | | | | Define the following terms: * assembler language * C language * ELF * interrupt service * software component * software unit Clarify: * task Update #3715. | ||||
* | eng: Add Python development guidelines | Sebastian Huber | 2020-03-19 | 2 | -0/+164 |
* | eng: Add glossary | Sebastian Huber | 2020-03-02 | 2 | -0/+62 |
| | | | | Update #3853. | ||||
* | eng: Fix typo | Sebastian Huber | 2020-02-25 | 1 | -1/+1 |
* | eng: Rework file template section | Sebastian Huber | 2020-02-24 | 1 | -30/+240 |
| | | | | Update #3053. | ||||
* | eng: Grammar fix | Sebastian Huber | 2020-02-10 | 1 | -1/+1 |
| | | | | Update #3199. | ||||
* | eng: Mention test framework buffer configuration | Sebastian Huber | 2020-02-10 | 1 | -2/+7 |
* | eng: Document test framework formatted output | Sebastian Huber | 2020-02-10 | 1 | -7/+23 |
* | Revert "common: Add URLs to manuals" | Sebastian Huber | 2020-02-04 | 1 | -2/+3 |
| | | | | | This reverts commit 1fdd3cf83d154af66ad0edf5094d93075063c7e0 and some follow up changes. | ||||
* | eng: Add Software Requirements Engineering chapter | Sebastian Huber | 2020-01-07 | 2 | -0/+1178 |
* | eng: Rework stakeholder chapter | Sebastian Huber | 2020-01-07 | 3 | -18/+20 |
* | eng: Rework preface and add mission statement | Sebastian Huber | 2020-01-07 | 4 | -23/+83 |
| | | | | | | | | Add mission statement based on the wiki page: https://devel.rtems.org/wiki/Mission_Statement Do format changes and some rewording. | ||||
* | Move contributing content from eng to user | Sebastian Huber | 2019-10-30 | 2 | -152/+0 |
* | eng: Update issue tracking section | Sebastian Huber | 2019-10-30 | 1 | -13/+8 |
* | eng: Add bibliography | Sebastian Huber | 2019-07-24 | 2 | -0/+7 |
* | eng: Rework Doxygen guidelines | Sebastian Huber | 2019-04-05 | 1 | -441/+235 |
| | | | | Update #3704. | ||||
* | bsp-howto: Move BSP Doxygen recommendations | Sebastian Huber | 2019-04-04 | 2 | -718/+0 |
* | eng: Add software test framework chapter | Sebastian Huber | 2019-03-27 | 2 | -0/+2255 |
* | eng: Change title to RTEMS Software Engineering | Sebastian Huber | 2019-03-27 | 2 | -5/+5 |
| | | | | Use a shorter title so that the PDF page header fits into one line. | ||||
* | eng: Reformat | Sebastian Huber | 2019-03-13 | 1 | -14/+14 |
* | Add unicode support for commonly used characters like copyright. | Chris Johns | 2019-02-28 | 1 | -1/+3 |
| | | | | | - This change makes the copyright character easier to see on editors lacking good unicode rendering support, ie terminals. | ||||
* | Use pathto() on the genindex URL to make it relative. | Chris Johns | 2019-02-15 | 1 | -2/+0 |
* | waf: Remove as many sys path hacks as we can. | Chris Johns | 2019-02-13 | 1 | -11/+7 |
| | | | | | | | | There are still sys.path hacks in the conf.py files. They cannot be removed because the instance of python running the sphinx-build command does not see our top level path hacks. I looked at using PYTHONPATH but I could not figure out how to set a process environ var for a waf build instance. | ||||
* | build: Prepend project common path | Sebastian Huber | 2019-02-08 | 2 | -2/+2 |
| | | | | | This avoids conflicts with standard packages such as PIL (Python Imaging Library). | ||||
* | Reformat and update copyright and license notices | Sebastian Huber | 2019-01-14 | 1 | -8/+5 |
| | | | | | | | | For everything before 2015 an OAR copyright is assumed. Later copyright notices are based on Git commits on a best effort basis. The copyright notices of the "RTEMS Software Engineering Handbook" and the "RTEMS CPU Architecture Supplement" are incomplete. | ||||
* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 28 | -28/+28 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 28 | -35/+31 |
* | Add common header.rst to reduce copy and paste | Sebastian Huber | 2019-01-09 | 1 | -23/+1 |
* | Eliminate UTF-8 characters except superscripted 2 in i2c | Joel Sherrill | 2018-12-20 | 7 | -18/+18 |
* | eng: Unicode char (U+200B) | Sebastian Huber | 2018-12-20 | 1 | -3/+3 |
* | eng/coding-conventions.rst: Convert TBD to Rest Format (GCI 2018) | Pritish Jain | 2018-12-17 | 1 | -2/+244 |
* | eng/coding-doxygen: Fix errors | Marçal Comajoan Cara | 2018-12-17 | 1 | -352/+360 |
| | | | | This work was part of GCI 2018. | ||||
* | eng/coding-file-hdr.rst: Fix file formatting (GCI 2018) | Sal | 2018-12-17 | 1 | -23/+25 |
* | eng/coding-doxygen.rst: Clean up and make subsubsections | Joel Sherrill | 2018-12-17 | 1 | -315/+362 |
