2023-03-23 | eng/vc-users.rst: Fix markup for subjectprefix | Kinsey Moore | 1 | -0/+1 | |
This was missing a line and causing the code block to not appear in the rendered document. | |||||
2022-12-14 | eng/vc-users.rst: Add commit message guidance | Joel Sherrill | 1 | -6/+77 | |
Closes #4274. | |||||
2022-11-03 | eng: show how to set local default subject-prefix | Gedare Bloom | 1 | -0/+5 | |
2021-03-16 | eng/vc-users: Set up patch message with repo name | Meh Mbeh Ida Delphine | 1 | -0/+8 | |
Added instructions on how to set up a patch message with a repo name. Author: Meh Mbeh Ida Delphine <idadelm@gmail.com> Date: Tue Mar 16 19:11:23 2021 +0100 | |||||
2019-01-11 | Simplify SPDX-License-Identifier comment | Sebastian Huber | 1 | -1/+1 | |
2019-01-11 | Use standard format for copyright lines | Sebastian Huber | 1 | -1/+1 | |
2018-12-20 | Eliminate UTF-8 characters except superscripted 2 in i2c | Joel Sherrill | 1 | -1/+1 | |
2018-12-20 | eng: Unicode char (U+200B) | Sebastian Huber | 1 | -3/+3 | |
2018-12-17 | eng/vc-users: Convert wiki page to Rest (GCI 2018) | Marçal Comajoan Cara | 1 | -2/+641 | |
Converted https://devel.rtems.org/wiki/Developer/Git/Users to Rest, and TBDs and wiki TODOs into comments. Also changed http links to https (the ones that are possible), corrected typos, updated learning resources links and added formattings. This work was part of GCI 2018. | |||||
2018-12-17 | Initial start of converting the Word outline to Rest | Joel Sherrill | 1 | -0/+11 | |
Thanks to Scott Zemerick <scott.zemerick@tmctechnologies.com> for the analysis and ideas that led to this. |
