path: root/eng/test-framework.rst (follow)
* eng: Add example to action requirements how-toSebastian Huber2021-03-191-0/+2
| | | | Update #3715.
* eng: Simplify "Load" environment reportingSebastian Huber2020-11-131-14/+7
| | | | | | | Report all runtime measurement environments with a name only and encode the worker count of the "Load" environment in the name. Update #3199.
* eng: Rename ValidCache environment in FullCacheSebastian Huber2020-11-131-7/+8
| | | | | | | This name better reflects the execution envirnoment in which the cache is fully loaded with valid data unrelated to the body request handler. Update #3199.
* eng/test-framework.rst -- Fix typoFrank Kühndel2020-09-181-3/+3
* eng: Update test framework chapterSebastian Huber2020-07-231-101/+311
| | | | | | | | Document the dynamic text fixtures, utility functions, and the interrupt test support. Reorder some sections and reword some paragraphs based on review comments. Update #3199.
* eng: Grammar fixSebastian Huber2020-02-101-1/+1
| | | | Update #3199.
* eng: Mention test framework buffer configurationSebastian Huber2020-02-101-2/+7
| | | | Update #3199.
* eng: Document test framework formatted outputSebastian Huber2020-02-101-7/+23
| | | | Update #3199.
* eng: Add software test framework chapterSebastian Huber2019-03-271-0/+2252
Update #3199.
