* | eng: Add example to action requirements how-to | Sebastian Huber | 2021-03-19 | 1 | -0/+2 |
| | | | | Update #3715. | ||||
* | eng: Simplify "Load" environment reporting | Sebastian Huber | 2020-11-13 | 1 | -14/+7 |
| | | | | | | | Report all runtime measurement environments with a name only and encode the worker count of the "Load" environment in the name. Update #3199. | ||||
* | eng: Rename ValidCache environment in FullCache | Sebastian Huber | 2020-11-13 | 1 | -7/+8 |
| | | | | | | | This name better reflects the execution envirnoment in which the cache is fully loaded with valid data unrelated to the body request handler. Update #3199. | ||||
* | eng/test-framework.rst -- Fix typo | Frank Kühndel | 2020-09-18 | 1 | -3/+3 |
* | eng: Update test framework chapter | Sebastian Huber | 2020-07-23 | 1 | -101/+311 |
| | | | | | | | | Document the dynamic text fixtures, utility functions, and the interrupt test support. Reorder some sections and reword some paragraphs based on review comments. Update #3199. | ||||
* | eng: Grammar fix | Sebastian Huber | 2020-02-10 | 1 | -1/+1 |
* | eng: Mention test framework buffer configuration | Sebastian Huber | 2020-02-10 | 1 | -2/+7 |
* | eng: Document test framework formatted output | Sebastian Huber | 2020-02-10 | 1 | -7/+23 |
* | eng: Add software test framework chapter | Sebastian Huber | 2019-03-27 | 1 | -0/+2252 |
Update #3199. |
