* | eng: Add reference to unspecified interfaces | Sebastian Huber | 2020-08-07 | 1 | -0/+4 |
| | | | | Update #3715. | ||||
* | eng: Add more variants of unspecified interfaces | Sebastian Huber | 2020-08-07 | 1 | -4/+16 |
* | eng: Add application config options how-to | Sebastian Huber | 2020-08-07 | 1 | -0/+119 |
* | eng: Refer to the rtems-central repository | Sebastian Huber | 2020-08-07 | 1 | -7/+6 |
| | | | | Close #4043. | ||||
* | eng: Partially revert previous commit | Sebastian Huber | 2020-08-06 | 1 | -18/+0 |
| | | | | | | | The previous commit contained more than just a typo fix. Remove this part. Update #3715. | ||||
* | eng: Fix typo | Sebastian Huber | 2020-08-06 | 1 | -2/+19 |
* | eng: Fix format of regular expressions | Sebastian Huber | 2020-07-28 | 1 | -9/+9 |
* | eng: Add ability to skip action transitions | Sebastian Huber | 2020-07-28 | 1 | -8/+43 |
| | | | | | | | | | | Sometimes the pre-conditions in an action requirement are not independent and it is necessary skip a certain set of pre-condition states. This should be used with care since no test code is run in these cases. There shall be a reason given why skipping a transition is justified. Update #3715. | ||||
* | eng: Support N/A in the action transitions | Sebastian Huber | 2020-07-28 | 1 | -4/+13 |
| | | | | | | | | Sometimes the pre-conditions in an action requirement are not independent and it is necessary to mark pre-conditions as not applicable in a particular transition. Update #3715. | ||||
* | eng: Add brief description to header file items | Sebastian Huber | 2020-07-28 | 1 | -1/+7 |
* | eng: Add requirement text to interface groups | Sebastian Huber | 2020-07-28 | 1 | -0/+6 |
| | | | | | | | This allows to state the requirement for an interface group directly in the item. Update #3715. | ||||
* | eng: Fix typo | Sebastian Huber | 2020-07-03 | 1 | -1/+1 |
* | eng: Reformat to maximize the text width | Sebastian Huber | 2020-07-03 | 1 | -72/+69 |
| | | | | | | Remove extra "X" character in some labels. Update #3715. | ||||
* | eng: Clarify action requirement specification | Sebastian Huber | 2020-06-17 | 1 | -6/+136 |
* | eng: Update action requirement specification | Sebastian Huber | 2020-06-10 | 1 | -1/+80 |
* | eng: Update specification how-to section | Sebastian Huber | 2020-06-08 | 1 | -0/+75 |
* | eng: Add a specification type for actions | Sebastian Huber | 2020-06-08 | 1 | -24/+377 |
| | | | | | | | | | Add support to specify functional requirements for actions (functions or macros) via a transition map of pre-conditions to post-conditions. This will be the work horse for functional requirements. Generation of corresponding validation tests is supported. Update #3715. | ||||
* | eng: Add generic attribute key types | Sebastian Huber | 2020-06-04 | 1 | -26/+37 |
* | eng: Simplify wording for specification items | Sebastian Huber | 2020-06-04 | 1 | -247/+217 |
* | eng: Add interface specification how-to | Sebastian Huber | 2020-06-01 | 2 | -0/+89 |
* | eng: Update requirements tooling section | Sebastian Huber | 2020-05-29 | 1 | -11/+22 |
* | eng: Add generated documentation of spec items | Sebastian Huber | 2020-05-29 | 5 | -408/+4255 |
| | | | | | | | | | The documentation of the specification items is generated by an RTEMS qualification tool from a specification of specification items. Move non-generated content to "req-for-req.rst". Update #3715. | ||||
* | eng: Split up requirements engineering chapter | Sebastian Huber | 2020-05-29 | 7 | -0/+1308 |
This allows to more easily generate the specification item section with a script using specification items. Update #3715. |
