2021-03-19 | eng: Add example to action requirements how-to | Sebastian Huber | 1 | -4/+404 | |
Update #3715. | |||||
2021-03-19 | eng: Document expressions in action requirements | Sebastian Huber | 1 | -11/+198 | |
2021-03-19 | eng: Add build/appl config clauses to how-to | Sebastian Huber | 1 | -0/+122 | |
2021-03-19 | eng: Update EARS syntax | Sebastian Huber | 2 | -41/+64 | |
The document used the EARS syntax from 2009 which slightly changed in 2016, see "Listens Learned (8 Lessons Learned Applying EARS)". The optional pre-conditions moved to the state-driven pattern. This refined syntax fits better to the action requirements. Update #3715. | |||||
2021-03-11 | eng: Clarify how-to for action requirements | Sebastian Huber | 1 | -9/+9 | |
Bring how-to in line with current action requirements. Update #3715. | |||||
2021-03-11 | eng: Clarify how-to for action requirements | Sebastian Huber | 1 | -1/+41 | |
2021-03-08 | eng: Clarify how-to for action requirements | Sebastian Huber | 1 | -2/+3 | |
2021-03-08 | eng: Add how-to for action requirements | Sebastian Huber | 1 | -1/+178 | |
2021-03-02 | eng: Fix typo | Sebastian Huber | 1 | -1/+1 | |
2021-02-08 | eng: Update test case item | Sebastian Huber | 1 | -26/+31 | |
2021-01-25 | Improve file header comment in generated files | Sebastian Huber | 1 | -3/+7 | |
2021-01-15 | eng: Add design group requirement item type | Sebastian Huber | 1 | -0/+24 | |
2020-11-27 | eng: Add performance specification items | Sebastian Huber | 1 | -113/+502 | |
Add items to specify runtime performance requirements. Update #3715. | |||||
2020-11-19 | eng: Fix typo | Sebastian Huber | 1 | -102/+103 | |
2020-11-12 | Improve automatically generated warning | Sebastian Huber | 1 | -5/+4 | |
2020-11-09 | eng: Add function attributes | Sebastian Huber | 1 | -0/+7 | |
2020-10-24 | eng: Replace spec2doc.py with spec2modules.py | Sebastian Huber | 1 | -7/+7 | |
2020-10-11 | eng: Add placement link role | Sebastian Huber | 1 | -0/+12 | |
2020-10-11 | eng: Move index-entries to all interfaces | Sebastian Huber | 1 | -6/+5 | |
2020-10-11 | Improve file header comment in generated files | Sebastian Huber | 1 | -4/+9 | |
2020-10-01 | eng: Clarify stlib build attribute | Sebastian Huber | 1 | -13/+32 | |
Update #4107. | |||||
2020-09-28 | eng: Fix typo | Sebastian Huber | 1 | -1/+1 | |
2020-09-18 | eng: Remove double blank line | Sebastian Huber | 1 | -1/+0 | |
2020-08-19 | eng: Add automatically generated warning | Sebastian Huber | 1 | -0/+7 | |
2020-08-19 | eng: Unify test attribute keys | Sebastian Huber | 1 | -19/+19 | |
2020-08-19 | eng: Add test header to test case | Sebastian Huber | 1 | -77/+82 | |
2020-08-19 | eng: Remove test name attribute | Sebastian Huber | 1 | -28/+0 | |
Derive the test name from the item UID. Update #3715. | |||||
2020-08-19 | eng: Add test case attributes | Sebastian Huber | 1 | -0/+18 | |
2020-08-07 | eng: Add reference to unspecified interfaces | Sebastian Huber | 1 | -0/+4 | |
2020-08-07 | eng: Add more variants of unspecified interfaces | Sebastian Huber | 1 | -4/+16 | |
2020-08-07 | eng: Add application config options how-to | Sebastian Huber | 1 | -0/+119 | |
2020-08-07 | eng: Refer to the rtems-central repository | Sebastian Huber | 1 | -7/+6 | |
Close #4043. | |||||
2020-08-06 | eng: Partially revert previous commit | Sebastian Huber | 1 | -18/+0 | |
The previous commit contained more than just a typo fix. Remove this part. Update #3715. | |||||
2020-08-06 | eng: Fix typo | Sebastian Huber | 1 | -2/+19 | |
2020-07-28 | eng: Fix format of regular expressions | Sebastian Huber | 1 | -9/+9 | |
2020-07-28 | eng: Add ability to skip action transitions | Sebastian Huber | 1 | -8/+43 | |
Sometimes the pre-conditions in an action requirement are not independent and it is necessary skip a certain set of pre-condition states. This should be used with care since no test code is run in these cases. There shall be a reason given why skipping a transition is justified. Update #3715. | |||||
2020-07-28 | eng: Support N/A in the action transitions | Sebastian Huber | 1 | -4/+13 | |
Sometimes the pre-conditions in an action requirement are not independent and it is necessary to mark pre-conditions as not applicable in a particular transition. Update #3715. | |||||
2020-07-28 | eng: Add brief description to header file items | Sebastian Huber | 1 | -1/+7 | |
2020-07-28 | eng: Add requirement text to interface groups | Sebastian Huber | 1 | -0/+6 | |
This allows to state the requirement for an interface group directly in the item. Update #3715. | |||||
2020-07-03 | eng: Fix typo | Sebastian Huber | 1 | -1/+1 | |
2020-07-03 | eng: Reformat to maximize the text width | Sebastian Huber | 1 | -72/+69 | |
Remove extra "X" character in some labels. Update #3715. | |||||
2020-06-17 | eng: Clarify action requirement specification | Sebastian Huber | 1 | -6/+136 | |
2020-06-10 | eng: Update action requirement specification | Sebastian Huber | 1 | -1/+80 | |
2020-06-08 | eng: Update specification how-to section | Sebastian Huber | 1 | -0/+75 | |
2020-06-08 | eng: Add a specification type for actions | Sebastian Huber | 1 | -24/+377 | |
Add support to specify functional requirements for actions (functions or macros) via a transition map of pre-conditions to post-conditions. This will be the work horse for functional requirements. Generation of corresponding validation tests is supported. Update #3715. | |||||
2020-06-04 | eng: Add generic attribute key types | Sebastian Huber | 1 | -26/+37 | |
2020-06-04 | eng: Simplify wording for specification items | Sebastian Huber | 1 | -247/+217 | |
2020-06-01 | eng: Add interface specification how-to | Sebastian Huber | 2 | -0/+89 | |
2020-05-29 | eng: Update requirements tooling section | Sebastian Huber | 1 | -11/+22 | |
2020-05-29 | eng: Add generated documentation of spec items | Sebastian Huber | 5 | -408/+4255 | |
The documentation of the specification items is generated by an RTEMS qualification tool from a specification of specification items. Move non-generated content to "req-for-req.rst". Update #3715. |
