The document used the EARS syntax from 2009 which slightly changed in
2016, see "Listens Learned (8 Lessons Learned Applying EARS)". The
optional pre-conditions moved to the state-driven pattern. This refined
syntax fits better to the action requirements.
Update #3715.
The documentation of the specification items is generated by an RTEMS
qualification tool from a specification of specification items.
Move non-generated content to "req-for-req.rst".
Update #3715.
This allows to more easily generate the specification item section with
a script using specification items.
Update #3715.
