path: root/eng/index.rst (follow)
* eng: Add BSP build system chapterSebastian Huber2020-09-131-0/+1
| | | | Update #3818.
* eng: Update test framework chapterSebastian Huber2020-07-231-2/+2
| | | | | | | | Document the dynamic text fixtures, utility functions, and the interrupt test support. Reorder some sections and reword some paragraphs based on review comments. Update #3199.
* eng: Split up requirements engineering chapterSebastian Huber2020-05-291-1/+1
| | | | | | | This allows to more easily generate the specification item section with a script using specification items. Update #3715.
* eng: Add glossarySebastian Huber2020-03-021-0/+1
| | | | Update #3853.
* eng: Add Software Requirements Engineering chapterSebastian Huber2020-01-071-0/+1
| | | | Update #3715.
* eng: Rework stakeholder chapterSebastian Huber2020-01-071-1/+1
* eng: Rework preface and add mission statementSebastian Huber2020-01-071-0/+1
| | | | | | | | Add mission statement based on the wiki page: https://devel.rtems.org/wiki/Mission_Statement Do format changes and some rewording.
* eng: Add bibliographySebastian Huber2019-07-241-0/+1
* eng: Add software test framework chapterSebastian Huber2019-03-271-0/+3
| | | | Update #3199.
* eng: Change title to RTEMS Software EngineeringSebastian Huber2019-03-271-3/+3
| | | | Use a shorter title so that the PDF page header fits into one line.
* eng: ReformatSebastian Huber2019-03-131-14/+14
* Add unicode support for commonly used characters like copyright.Chris Johns2019-02-281-1/+3
| | | | | - This change makes the copyright character easier to see on editors lacking good unicode rendering support, ie terminals.
* Use pathto() on the genindex URL to make it relative.Chris Johns2019-02-151-2/+0
* Reformat and update copyright and license noticesSebastian Huber2019-01-141-8/+5
| | | | | | | | For everything before 2015 an OAR copyright is assumed. Later copyright notices are based on Git commits on a best effort basis. The copyright notices of the "RTEMS Software Engineering Handbook" and the "RTEMS CPU Architecture Supplement" are incomplete.
* Simplify SPDX-License-Identifier commentSebastian Huber2019-01-111-1/+1
* Use standard format for copyright linesSebastian Huber2019-01-111-5/+3
* Add common header.rst to reduce copy and pasteSebastian Huber2019-01-091-23/+1
* Initial start of converting the Word outline to RestJoel Sherrill2018-12-171-0/+61
Thanks to Scott Zemerick <scott.zemerick@tmctechnologies.com> for the analysis and ideas that led to this.
