* | eng: Add glossary | Sebastian Huber | 2020-03-02 | 1 | -0/+1 |
| | | | | Update #3853. | ||||
* | eng: Add Software Requirements Engineering chapter | Sebastian Huber | 2020-01-07 | 1 | -0/+1 |
| | | | | Update #3715. | ||||
* | eng: Rework stakeholder chapter | Sebastian Huber | 2020-01-07 | 1 | -1/+1 |
* | eng: Rework preface and add mission statement | Sebastian Huber | 2020-01-07 | 1 | -0/+1 |
| | | | | | | | | Add mission statement based on the wiki page: https://devel.rtems.org/wiki/Mission_Statement Do format changes and some rewording. | ||||
* | eng: Add bibliography | Sebastian Huber | 2019-07-24 | 1 | -0/+1 |
* | eng: Add software test framework chapter | Sebastian Huber | 2019-03-27 | 1 | -0/+3 |
| | | | | Update #3199. | ||||
* | eng: Change title to RTEMS Software Engineering | Sebastian Huber | 2019-03-27 | 1 | -3/+3 |
| | | | | Use a shorter title so that the PDF page header fits into one line. | ||||
* | eng: Reformat | Sebastian Huber | 2019-03-13 | 1 | -14/+14 |
* | Add unicode support for commonly used characters like copyright. | Chris Johns | 2019-02-28 | 1 | -1/+3 |
| | | | | | - This change makes the copyright character easier to see on editors lacking good unicode rendering support, ie terminals. | ||||
* | Use pathto() on the genindex URL to make it relative. | Chris Johns | 2019-02-15 | 1 | -2/+0 |
* | Reformat and update copyright and license notices | Sebastian Huber | 2019-01-14 | 1 | -8/+5 |
| | | | | | | | | For everything before 2015 an OAR copyright is assumed. Later copyright notices are based on Git commits on a best effort basis. The copyright notices of the "RTEMS Software Engineering Handbook" and the "RTEMS CPU Architecture Supplement" are incomplete. | ||||
* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 1 | -1/+1 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 1 | -5/+3 |
* | Add common header.rst to reduce copy and paste | Sebastian Huber | 2019-01-09 | 1 | -23/+1 |
* | Initial start of converting the Word outline to Rest | Joel Sherrill | 2018-12-17 | 1 | -0/+61 |
Thanks to Scott Zemerick <scott.zemerick@tmctechnologies.com> for the analysis and ideas that led to this. |
