* | eng: Update the python template, add a shell template | Chris Johns | 2020-09-01 | 1 | -4/+59 |
* | eng: fix typo in coding-file-hdr.rst | G S Niteesh Babu | 2020-07-11 | 1 | -1/+1 |
* | eng: Adjust config.h include | Sebastian Huber | 2020-04-15 | 1 | -1/+1 |
| | | | | Use variant used by most source files. | ||||
* | eng: Fix typo | Sebastian Huber | 2020-02-25 | 1 | -1/+1 |
* | eng: Rework file template section | Sebastian Huber | 2020-02-24 | 1 | -30/+240 |
| | | | | Update #3053. | ||||
* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 1 | -1/+1 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 1 | -1/+1 |
* | eng/coding-file-hdr.rst: Fix file formatting (GCI 2018) | Sal | 2018-12-17 | 1 | -23/+25 |
* | coding-doxygen-bsp.rst, coding-file-hdr.rst: Fix formatting | Joel Sherrill | 2018-12-17 | 1 | -26/+29 |
* | coding-file-hdr: Convert TBD to Rest Format (GCI 2018) | Pritish Jain | 2018-12-17 | 1 | -3/+33 |
* | Initial start of converting the Word outline to Rest | Joel Sherrill | 2018-12-17 | 1 | -0/+10 |
Thanks to Scott Zemerick <scott.zemerick@tmctechnologies.com> for the analysis and ideas that led to this. |
