* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 3 | -3/+3 |
* | Add common header.rst to reduce copy and paste | Sebastian Huber | 2019-01-09 | 1 | -23/+1 |
* | glossary.rst: Fix grammar errors (GCI 2018) | Aneendya | 2018-11-16 | 1 | -2/+2 |
* | Update the copyright year. | Chris Johns | 2018-10-19 | 1 | -1/+1 |
* | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 2018-08-21 | 2 | -5/+1 |
| | | | | | | | | | | | | - Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | ||||
* | Add indexes to all documents. | Chris Johns | 2017-11-12 | 2 | -3/+5 |
| | | | | Update #3229. | ||||
* | Change RTEMS version to 5 | Sebastian Huber | 2017-11-09 | 1 | -5/+5 |
| | | | | Update #3220. | ||||
* | Eclipse: Fix TOC and glossary licence comment. | Chris Johns | 2017-09-04 | 2 | -5/+1 |
* | Update copyright notices. | Chris Johns | 2017-08-11 | 1 | -4/+5 |
* | waf: Cleaner formatting to see the importing. | Chris Johns | 2017-03-27 | 1 | -2/+7 |
* | Use a single top level version number. | Chris Johns | 2017-03-20 | 1 | -4/+5 |
* | Update document titles for consistency | Joel Sherrill | 2017-01-11 | 1 | -3/+3 |
* | Update version/revision to 4.11.99 | Sebastian Huber | 2016-12-21 | 1 | -2/+2 |
* | eclipse: Fix heading levels. | Chris Johns | 2016-11-09 | 4 | -7/+37 |
* | Add Eclipse user manual for RTEMS. | Chris Johns | 2016-05-20 | 6 | -0/+477 |
