2019-01-11 | Remove superfluous "All rights reserved." | Sebastian Huber | 3 | -3/+0 | |
2019-01-11 | Use standard format for copyright lines | Sebastian Huber | 3 | -3/+3 | |
2019-01-09 | Add common header.rst to reduce copy and paste | Sebastian Huber | 1 | -23/+1 | |
2018-11-16 | glossary.rst: Fix grammar errors (GCI 2018) | Aneendya | 1 | -2/+2 | |
2018-10-19 | Update the copyright year. | Chris Johns | 1 | -1/+1 | |
2018-08-21 | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 2 | -5/+1 | |
- Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | |||||
2017-11-12 | Add indexes to all documents. | Chris Johns | 2 | -3/+5 | |
Update #3229. | |||||
2017-11-09 | Change RTEMS version to 5 | Sebastian Huber | 1 | -5/+5 | |
Update #3220. | |||||
2017-09-04 | Eclipse: Fix TOC and glossary licence comment. | Chris Johns | 2 | -5/+1 | |
2017-08-11 | Update copyright notices. | Chris Johns | 1 | -4/+5 | |
2017-03-27 | waf: Cleaner formatting to see the importing. | Chris Johns | 1 | -2/+7 | |
2017-03-20 | Use a single top level version number. | Chris Johns | 1 | -4/+5 | |
2017-01-11 | Update document titles for consistency | Joel Sherrill | 1 | -3/+3 | |
2016-12-21 | Update version/revision to 4.11.99 | Sebastian Huber | 1 | -2/+2 | |
2016-11-09 | eclipse: Fix heading levels. | Chris Johns | 4 | -7/+37 | |
2016-05-20 | Add Eclipse user manual for RTEMS. | Chris Johns | 6 | -0/+477 | |
