* | build: Prepend project common path | Sebastian Huber | 2019-02-08 | 2 | -2/+2 |
| | | | | | This avoids conflicts with standard packages such as PIL (Python Imaging Library). | ||||
* | Reformat and update copyright and license notices | Sebastian Huber | 2019-01-14 | 1 | -8/+5 |
| | | | | | | | | For everything before 2015 an OAR copyright is assumed. Later copyright notices are based on Git commits on a best effort basis. The copyright notices of the "RTEMS Software Engineering Handbook" and the "RTEMS CPU Architecture Supplement" are incomplete. | ||||
* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 6 | -6/+6 |
* | Remove superfluous "All rights reserved." | Sebastian Huber | 2019-01-11 | 2 | -2/+0 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 2 | -4/+2 |
* | Add common header.rst to reduce copy and paste | Sebastian Huber | 2019-01-09 | 1 | -23/+1 |
* | Update the copyright year. | Chris Johns | 2018-10-19 | 1 | -1/+1 |
* | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 2018-08-21 | 2 | -5/+1 |
| | | | | | | | | | | | | - Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | ||||
* | Add indexes to all documents. | Chris Johns | 2017-11-12 | 2 | -2/+5 |
| | | | | Update #3229. | ||||
* | Shorten the name of the BSP and Device Driver Development Guide | Joel Sherrill | 2017-10-12 | 1 | -2/+2 |
| | | | | | | | | | | | | | Old name: RTEMS BSP and Device Driver Development Guide This is long and causes problems in the PDF output. This patch changes the name to: RTEMS BSP and Driver Guide Closes #3141. | ||||
* | coverpage: Fix repeated entries. | Chris Johns | 2017-08-11 | 1 | -0/+2 |
| | | | | Closes #2865. | ||||
* | Update copyright notices. | Chris Johns | 2017-08-11 | 1 | -5/+8 |
* | waf: Cleaner formatting to see the importing. | Chris Johns | 2017-03-27 | 1 | -2/+7 |
* | Use a single top level version number. | Chris Johns | 2017-03-20 | 1 | -4/+5 |
* | Update document titles for consistency | Joel Sherrill | 2017-01-11 | 2 | -4/+4 |
* | Update version/revision to 4.11.99 | Sebastian Huber | 2016-12-21 | 1 | -2/+2 |
* | develenv: Fix header levels. | Chris Johns | 2016-11-09 | 7 | -10/+11 |
* | Remove the old files. | Chris Johns | 2016-10-29 | 1 | -1393/+0 |
* | Update the file list to the 4.11 directory structure. | Chris Johns | 2016-10-27 | 1 | -116/+3 |
* | develenv/sample.rst: Correct formatting error | Joel Sherrill | 2016-10-27 | 1 | -1/+0 |
* | develenv: Fix build errors for real | Joel Sherrill | 2016-10-27 | 3 | -9/+6 |
* | develenv: Fix build errors | Joel Sherrill | 2016-10-27 | 3 | -19/+20 |
* | Fix develenv. Needs more fixes. | Chris Johns | 2016-10-27 | 6 | -767/+603 |
* | Set SPDX License Identifier in each source file. | Chris Johns | 2016-05-20 | 7 | -0/+14 |
* | Add 'waf linkcheck' to check external references. | Amar Takhar | 2016-05-02 | 1 | -1/+1 |
* | Add PDF generation support use with --pdf | Amar Takhar | 2016-05-02 | 2 | -6/+5 |
* | Add support for spellchecking with a custom dictionary. | Amar Takhar | 2016-05-02 | 1 | -1/+1 |
| | | | | | | | | | | | | | | To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar. | ||||
* | Convert all Unicode to ASCII(128) | Amar Takhar | 2016-05-02 | 4 | -14/+14 |
* | Rework how conf.py is handled. | Amar Takhar | 2016-05-02 | 2 | -9/+9 |
| | | | | Needed to switch due to increasing complexity. | ||||
* | Move preface/intro one level up so the section is unnumbered. | Amar Takhar | 2016-05-02 | 1 | -1/+2 |
* | Split document. | Amar Takhar | 2016-05-02 | 7 | -1/+1329 |
* | Fix warnings. | Amar Takhar | 2016-05-02 | 1 | -25/+10 |
* | Initial reST documentation using Sphinx. | Amar Takhar | 2016-05-02 | 3 | -0/+1431 |
