2018-08-21 | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 2 | -5/+1 | |
- Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | |||||
2017-11-12 | Add indexes to all documents. | Chris Johns | 2 | -2/+5 | |
Update #3229. | |||||
2017-10-12 | Shorten the name of the BSP and Device Driver Development Guide | Joel Sherrill | 1 | -2/+2 | |
Old name: RTEMS BSP and Device Driver Development Guide This is long and causes problems in the PDF output. This patch changes the name to: RTEMS BSP and Driver Guide Closes #3141. | |||||
2017-08-11 | coverpage: Fix repeated entries. | Chris Johns | 1 | -0/+2 | |
Closes #2865. | |||||
2017-08-11 | Update copyright notices. | Chris Johns | 1 | -5/+8 | |
2017-03-27 | waf: Cleaner formatting to see the importing. | Chris Johns | 1 | -2/+7 | |
2017-03-20 | Use a single top level version number. | Chris Johns | 1 | -4/+5 | |
2017-01-11 | Update document titles for consistency | Joel Sherrill | 2 | -4/+4 | |
2016-12-21 | Update version/revision to 4.11.99 | Sebastian Huber | 1 | -2/+2 | |
2016-11-09 | develenv: Fix header levels. | Chris Johns | 7 | -10/+11 | |
2016-10-29 | Remove the old files. | Chris Johns | 1 | -1393/+0 | |
2016-10-27 | Update the file list to the 4.11 directory structure. | Chris Johns | 1 | -116/+3 | |
2016-10-27 | develenv/sample.rst: Correct formatting error | Joel Sherrill | 1 | -1/+0 | |
2016-10-27 | develenv: Fix build errors for real | Joel Sherrill | 3 | -9/+6 | |
2016-10-27 | develenv: Fix build errors | Joel Sherrill | 3 | -19/+20 | |
2016-10-27 | Fix develenv. Needs more fixes. | Chris Johns | 6 | -767/+603 | |
2016-05-20 | Set SPDX License Identifier in each source file. | Chris Johns | 7 | -0/+14 | |
2016-05-02 | Add 'waf linkcheck' to check external references. | Amar Takhar | 1 | -1/+1 | |
2016-05-02 | Add PDF generation support use with --pdf | Amar Takhar | 2 | -6/+5 | |
2016-05-02 | Add support for spellchecking with a custom dictionary. | Amar Takhar | 1 | -1/+1 | |
To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar. | |||||
2016-05-02 | Convert all Unicode to ASCII(128) | Amar Takhar | 4 | -14/+14 | |
2016-05-02 | Rework how conf.py is handled. | Amar Takhar | 2 | -9/+9 | |
Needed to switch due to increasing complexity. | |||||
2016-05-02 | Move preface/intro one level up so the section is unnumbered. | Amar Takhar | 1 | -1/+2 | |
2016-05-02 | Split document. | Amar Takhar | 7 | -1/+1329 | |
2016-05-02 | Fix warnings. | Amar Takhar | 1 | -25/+10 | |
