* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 1 | -1/+1 |
* | Remove superfluous "All rights reserved." | Sebastian Huber | 2019-01-11 | 1 | -1/+0 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 1 | -2/+1 |
* | Shorten the name of the BSP and Device Driver Development Guide | Joel Sherrill | 2017-10-12 | 1 | -2/+2 |
| | | | | | | | | | | | | | Old name: RTEMS BSP and Device Driver Development Guide This is long and causes problems in the PDF output. This patch changes the name to: RTEMS BSP and Driver Guide Closes #3141. | ||||
* | develenv: Fix header levels. | Chris Johns | 2016-11-09 | 1 | -1/+1 |
* | Update the file list to the 4.11 directory structure. | Chris Johns | 2016-10-27 | 1 | -116/+3 |
* | develenv: Fix build errors for real | Joel Sherrill | 2016-10-27 | 1 | -2/+2 |
* | develenv: Fix build errors | Joel Sherrill | 2016-10-27 | 1 | -2/+3 |
* | Fix develenv. Needs more fixes. | Chris Johns | 2016-10-27 | 1 | -427/+312 |
* | Set SPDX License Identifier in each source file. | Chris Johns | 2016-05-20 | 1 | -0/+2 |
* | Convert all Unicode to ASCII(128) | Amar Takhar | 2016-05-02 | 1 | -8/+8 |
* | Split document. | Amar Takhar | 2016-05-02 | 1 | -0/+639 |
