2016-10-28 | cpu_supplement: Fixed numbered list | Joel Sherrill | 1 | -24/+24 | |
2016-10-28 | powerpc, sparc, sparc64: Correct tables | Joel Sherrill | 3 | -73/+57 | |
2016-10-29 | Remove the old files. | Chris Johns | 1 | -4762/+0 | |
2016-10-07 | Clean up the CPU Supplement. | Chris Johns | 19 | -2420/+1985 | |
2016-05-20 | Set SPDX License Identifier in each source file. | Chris Johns | 21 | -0/+42 | |
2016-05-02 | Add 'waf linkcheck' to check external references. | Amar Takhar | 1 | -1/+1 | |
2016-05-02 | Add PDF generation support use with --pdf | Amar Takhar | 2 | -6/+5 | |
2016-05-02 | Add support for spellchecking with a custom dictionary. | Amar Takhar | 1 | -1/+1 | |
To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar. | |||||
2016-05-02 | Convert all Unicode to ASCII(128) | Amar Takhar | 12 | -86/+86 | |
2016-05-02 | Rework how conf.py is handled. | Amar Takhar | 2 | -9/+9 | |
Needed to switch due to increasing complexity. | |||||
2016-05-02 | Rename old document for reference only. | Amar Takhar | 1 | -0/+0 | |
2016-05-02 | Split document into seperate files by section. | Amar Takhar | 20 | -1/+4723 | |
2016-05-02 | Fix warnings. | Amar Takhar | 1 | -19/+28 | |
