path: root/cpu-supplement (follow)
* cpu-supplement: Update TLS support statusSebastian Huber2017-06-121-1/+1
| | | | Close #2468.
* waf: Cleaner formatting to see the importing.Chris Johns2017-03-271-2/+7
* Use a single top level version number.Chris Johns2017-03-201-6/+5
* c-user: Add support for references via bibtexSebastian Huber2017-01-184-1/+10
| | | | | | https://sphinxcontrib-bibtex.readthedocs.io/en/latest/index.html Update #2871.
* Update document titles for consistencyJoel Sherrill2017-01-112-5/+5
* Remove references to SPARC/SIS BSP. Also clean up old ERC32 references.Joel Sherrill2017-01-111-22/+5
| | | | updates #2810.
* Update version/revision to 4.11.99Sebastian Huber2016-12-211-1/+1
* cpu-supplement: Document PowerPC SPRG0-2 usageSebastian Huber2016-11-101-0/+11
* cpu-supplement: Fix the project label.Chris Johns2016-11-091-0/+2
* cpu-supplement: Fix header levels.Chris Johns2016-11-0921-23/+24
* Rename all manuals with an _ to have a -. It helps released naming of files.Chris Johns2016-11-0322-0/+4329
