* | cpu-supplement: Update TLS support status | Sebastian Huber | 2017-06-12 | 1 | -1/+1 | |
| | | | | Close #2468. | |||||
* | waf: Cleaner formatting to see the importing. | Chris Johns | 2017-03-27 | 1 | -2/+7 | |
* | Use a single top level version number. | Chris Johns | 2017-03-20 | 1 | -6/+5 | |
* | c-user: Add support for references via bibtex | Sebastian Huber | 2017-01-18 | 4 | -1/+10 | |
| | | | | | | https://sphinxcontrib-bibtex.readthedocs.io/en/latest/index.html Update #2871. | |||||
* | Update document titles for consistency | Joel Sherrill | 2017-01-11 | 2 | -5/+5 | |
* | Remove references to SPARC/SIS BSP. Also clean up old ERC32 references. | Joel Sherrill | 2017-01-11 | 1 | -22/+5 | |
| | | | | updates #2810. | |||||
* | Update version/revision to 4.11.99 | Sebastian Huber | 2016-12-21 | 1 | -1/+1 | |
* | cpu-supplement: Document PowerPC SPRG0-2 usage | Sebastian Huber | 2016-11-10 | 1 | -0/+11 | |
* | cpu-supplement: Fix the project label. | Chris Johns | 2016-11-09 | 1 | -0/+2 | |
* | cpu-supplement: Fix header levels. | Chris Johns | 2016-11-09 | 21 | -23/+24 | |
* | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 2016-11-03 | 22 | -0/+4329 | |
