path: root/cpu-supplement/wscript (unfollow)
2019-02-13waf: Remove as many sys path hacks as we can.Chris Johns1-11/+7
There are still sys.path hacks in the conf.py files. They cannot be removed because the instance of python running the sphinx-build command does not see our top level path hacks. I looked at using PYTHONPATH but I could not figure out how to set a process environ var for a waf build instance.
2019-02-08build: Prepend project common pathSebastian Huber1-1/+1
This avoids conflicts with standard packages such as PIL (Python Imaging Library).
2017-03-27waf: Cleaner formatting to see the importing.Chris Johns1-2/+7
2016-11-03Rename all manuals with an _ to have a -. It helps released naming of files.Chris Johns1-0/+0
2016-05-02Add 'waf linkcheck' to check external references.Amar Takhar1-1/+1
2016-05-02Add PDF generation support use with --pdfAmar Takhar1-6/+1
2016-05-02Add support for spellchecking with a custom dictionary.Amar Takhar1-1/+1
To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar.
2016-05-02Rework how conf.py is handled.Amar Takhar1-9/+1
Needed to switch due to increasing complexity.
